Question about Mitsubishi WS-65611 65" Rear Projection Television
GREEN LIGHT FLASHES (70 + TIMES),THEN SHUTS OFF AND TV WONT START. ALL STANBY VOLTAGES OK MICRO VOLTAGES OK CRYSTAL OK WHEN DEPRESSING POWER BUTON -POWER-IN PIN ON MICRO GOES LOW, BUT POWER1 PIN DOESN'T GO HI FORSSING TV TO TURN ON - ALL SWITCHED VOLTAGES SEEMS TO BE OK, NO HD TO GET HV ANY SUGGESTIONS WHAT COULD IT BE? REGARDS pete
  • petargrbesa Jul 23, 2009
    the only stand-by voltages we have checked are 5v, and 12v. they are there. within the power supply, since there is no P-ON1 voltage from the micro, we checked that micro, and found vcc ok, and the xtal is oscillating. in an attempt to turn the supply on, we shunted the collector of Q9A51 to ground, forcing it on. the main power came on, and we read 210v on the 220v supply, and 110v on the 110 supply, etc at transformer T-9A50. there was still no h.v., and the set did not come on any further. please continue to assist us on this model. Thanks.... John Steinway
  • Mitsubishi Master
  • 5,807 Answers
standby voltages? what do you get?
try checking B+, can you get the voltage reading at the positive side of the diode at the secondary side of the chopper?
indicate all DC voltages you can measure on it.
try this:
if voltage is low,
you might have a partially shorted flyback
if voltage zero,
might have shorted diode
might have shorted horizontal output
if voltage is OK say 110V, there is no drive in horizontal output transistor, might be blocked, will not oscillate, will not turn on
hope this helps, thanks for using Fixya!
Posted on Jul 23, 2009
  • Rommel Cana
    Rommel Cana Jul 23, 2009
    try to trace down the circuit from base of the horiz out, it needs signal to oscillate, might be blocked
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Televison & Video
Sony kdl-46w5100 shuts itself off then goes to stanby flashing 10 times
I have the same tv with the same problem, replace the power supply boards and still had same problem, called in a tv repair man and I was told I have a main board problem bu board Watch Dog Timer used to track micro processors, led flashing 10 times cost around $425 parts and service call
Feb 24, 2012 | Sony KDL Televison & Video
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv won't come on
red stanby light just flashes and the tv wont come on
Apr 26, 2008 | Samsung HCN436W 43" Rear Projection...
Will Not Turn On
hi,
iandojay
check PW suppy is ok check all voltages in the micro controller IC
Dec 05, 2007 | Televison & Video
Mitsubishi WS-65611 65" Rear Projection Television Logo
95 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
