Won't switch on immediately - clicking all the time ????
I use the remote to switch on. The TV clicks for ages as if it is trying to switch on, it eventually does, but this is getting to be a pest. Have changed the remote batteries - still doing it. However, when the set has been on for some time and I switch it off using the remote, I can switch it back on again immediately without all the clicking. What could be wrong as this problem is driving me nuts !!!
    Novelist:
  • 133 Answers
Your unit cycles/ticks with first power up but seems to work fine after it warms up. This strongly suggests there's a dried up/partially blown filter capacitor (electrolytic) at the main power supply section or somewhere else (this may be the main filter capacitor - the big one), or possibly a faulty solder connection on one of the capacitors or other components.
Check for any loose solder connections and resolder these. Also see if any of the electrolytic caps (aluminium cylinders with plastic foil wrap) have a deformed/blown out top, if there are any, they are most likely the cause, if you can't spot any, then you'll need a different approach, which includes voltage measuring, paralleling capacitors with good ones, or replacing them one by one until you've found the one that's causing trouble, but this can get somewhat time consuming.
These are just some of the possibilities, the problem may as well be somewhere else, but the behaviour of your TV set points to the causes i've mentioned above, and i really hope you can get it fixed...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
The tv does not turn on when switching on?
power supply board faulty......
cheers
Dec 04, 2016 | Televison & Video
Unable to turn Tv on
did you hear any popping sound/clicking, or any like that you think that tv still response when you try to turn it ON
Sep 10, 2008 | Televison & Video
Zenith a27b41w won't turn on. It just clicks whether using the remote or the button on the tv
Probably a power supply problem. The click could be a relay closing
Nov 04, 2012 | Televison & Video
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
Pioneer SDT50W1 rear projection TV clicks off when switched on.
Hey dudes...even i hav had the same problem that too with the same model specified here..Its a problem actually concerned with the power circuit boards of the tv. Its best to get it checked by an authorized technician. For me I had to replace a transistor on one of the boards. But after that my tv came up with a new problem....the colours appear like rainbows! Could nyone xplain y dis is happening?
Feb 06, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
