Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
The Ice Maker is not making ice.
The water is coming in throught the line, and up to the water dispencer, but the water is not filling the tray.
  • Admiral Master
  • 4,655 Answers
You should have two sides to the water control valve. One for the dispenser and one for the ice maker. Fill ice maker with tap water if it freezes and dumps then the water control valve is defective and will need replaced. If not we need to have a look at the thermostat in your ice maker. Sea Breeze
Posted on Jul 23, 2009
    Problem Solver:
  • 7 Answers
In the freezer compartment I would take the back panel off and thaw the coils with a hair dryer as well as the ice maker. I would also check the ice maker for damage to the gear section as this would result in a timing issue.
FRIGIDAIRE FAF54272LWO
Replace the dispenser assembly, which should come with a dispensor selector motor. The part number for that is 134409320
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Frigidaire ATF6000ES Front Load Washer
Water dispencer from inside fridge isnt dispencing water. makes noise like it wants to but wont. can my water line be frozen? my fridge is usualy pretty bare and the temp is on 6.
It is very common for the water dispensing tube to become frozen if there is a slow drip coming from the water fill solenoid in the back of the refrigerator.
May 29, 2011 | Refrigerators
Water drips from dispencer
make sure if the water tray in the dispenser if not over flowing. or there mite be more frozen ice formed in and around the dispenser.
defreeze it and drain the water wash it and fill the water tray.
if this not your problem. Then check if the dispenser is not broken. live consult with a Refrigerators consultant Thanks for rating Good luck
Dec 24, 2010 | Refrigerators
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
GE Profile PSS26SGRB SS small water seep
under the trim there are 2 openings on on each side insert a flat head screw driver and twist so it will unlock and then it will be off hopefully you dont have to remove all insternal parts inside dispencer i will try one tomorrow at work and let you know
Oct 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
NO WATER DISPENSING FOR ICE
did you clear out the fill tube in the freezer section that lets the water enter the ice maker, it could be frozen
it the line and the tube are clear then replace the water valve
May 11, 2008 | Kenmore 26.0 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
168 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
