Question about Garden
How do i put a new line on a bosch art 23 easy trimmer (electric) as there is a little plastic cover preventing me from doing this?
  • glenncass
    glenncass May 11, 2012
    so wheres the *** ***g solution
  • 313 Answers
SOURCE: black and decker trimmer
can you specify what model
Posted on Jun 02, 2008
SOURCE: Ryobi Trimmer
To install string in the Ryobi you do not have to disassemble anything: Line up the two arrows on the inner and outer reel, remove any excess string, cut two pieces of string about 10 feet, feed line in the side holes, secure line in hole where it comes out the bottom (it only takes about 1/4in. to do so), pull strings tight, then turn the inner reel counter clockwise to wind it. If it sticks a little just pull line a little.
To remove the inner spool in order to remove line that has broken inside, to clean the mechanism, or to perform other maintenance, grasp the outer reel and unscrew the bump knob counter-clockwise. Mine is often very tight and requires pliers to get enough leverage. While you are in there, clean the inner reel and the inside of the outer reel to improve feed performance. The shaft rarely needs cleaning. Do not lubricate. After re-installing the reel, add string (0.080") as described above.
Posted on May 18, 2009
  • 133 Answers
SOURCE: how do i install a new trimmer line ie plastic
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
rycgl
  • 1545 Answers
SOURCE: how do I replace the line in an 11 inch electric
All I can do is refer you to the manufacturer's instructions. See page 5 after downloading your user manual. If you can not turn the cap off, then the cap is possibly cross threaded onto the shaft end and/or the threaded end if the driveshaft is stripped. See if the user instructions are of help to you.
http://www.toro.com/en-us/Homeowner/Yard-Tools/Trimmers/Pages/Model.aspx?pid=51347-11-Inch-Electric-Trimmer
Posted on Jun 08, 2011
  • 6 Answers
SOURCE: We have inherrited a Bosch art 23 combitrim
go online and order one if you cant see if the owner still has it try ways like that
Posted on Jul 10, 2011
Need parts for American Gardner Yardstick model YS24. Specificly the line head assembly.
How to make a spool cap cover for an American Gardener YS24 (Weedeater XLT24) Trimmer
If you've tried to buy parts lately for your trimmer, you've noticed they are harder and harder to find. In fact, I was unable to find a spool cap cover, so I came up with this work-around.
Before you start this project, it's important to save any parts from the old spool cover-especially the top, if you can. The top is needed to make a spacer for the new cover that will still allow you to "bump" out the string.
I used a Craftsman 71-64215 replacement spool retainer to make my new spool cover cap. It fits the Craftsman C3 19.2 volt 74381 String Trimmer (CRAC06540 spool cap). I found this cap at a local Ace Hardware, but apparently it is also getting hard to find-I googled the Ace Hardware number to find it on the web-"7314644 cap." I bought a couple extra from HardwareDistributors.com. Note that the diameter of the cover at the tabs is the same diameter of the old cover-although the diameter of the cap is slightly larger.
Take the old cover, and using the tab from the old cover, mark a line on the new tabs the same width as the old. Make sure you center the old tab on the new tab so you will remove the same amount of plastic from each side of the new tab. I used a dremel tool with the cutoff wheels to cut the tabs on the new cap to the same size as the old cap.
If you look at the new cap, there is a round plastic circle ridge on the bottom of the cap. If you look closely you can see a slight indention, or discoloration on the top of the new cap matching the circle on the bottom. You need to cut the plastic out of the new cap matching the plastic circle. I used a dremel tool with a metal cylindrical grinder to do that.
Once you get everything cut, put the old cap into the new cap so that the spokes face down toward the similar spokes on the top of the spool. You may have to trim the old cap so it fits into the new cap.
Finally, snap everything together into your trimmer-don't forget the spring. Note that the new cap has about a 1/8 inch gap above the spool. However, this doesn't seem to affect the trimmer-and you can still "bump" the head to eject the string.
Sep 01, 2013 | Weedeater Garden
I have ryobi 137r . i cannot ge the head off to replace the string
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,don't forget to give 4 thumbs up,any comments welcome,thank you, ``
Dec 23, 2011 | Ryobi 15" Electric Factory Reconditioned...
I HAVE A RYOBI RLT 580. MY PROBLEM IS THAT THE COVER ON THE SPINDLE BROKE .THIS IS THE COVER THAT CLOSES THE LINE AND SPRING AT THE BOTTOM. NEED A NEW ONE. CAN ANYBODY HELP ME
This is all I could find for that model. Very little info is available on the RLT580, but I am sure you can get the part you need somewhere. Is this unit GAS or Electric?
http://www.ereplacementparts.com/search_result.php
Sep 05, 2011 | Ryobi 15" Electric Factory Reconditioned...
I have a TB525EC trimmer with the "new" string
Great question! You can always go to the Home Depot and purchase a "universal-type" retro head and if it doesn't fit correctly, just return it for a refund or go on a site like Ebay and buy a genuine Troy Bilt retro type string head. I bet they will fit.
Nov 12, 2010 | Troy Garden
Troybilt 4 cycle trimmer (TB475ss) won't start. New tank, new plug, new gas??? Will occasionally start, run for about 10-15 secs, then stops. Won't restart. Help!
Take the plastic cover off that covers the muffler and cylinder head. I've had 2 cylinder heads crack. The trimmer still ran but had little to no power and would not throttle up. First head cracked at the head bolts. The second one cracked above the bolts. The side that has the carb and fuel tank is harder to see and you must remove the carb and fuel tank to check. Also I've read online that this trimmer has a problem with the fuel line cracking at the bulb and in the tank.
Sep 12, 2009 | Garden
How to load new line
Well i don't know what kind of line holder yours has, but they either a bolted on with a big nut that you'll need to unscrew while holding the line holder(so your not just spinning it around) or it has a slip and lock type cover, which in that case you hold the barrel of the line holder and then grab the cover and twist it to take it off, then you just take out the line spool, and put new line in it, their will be little holes that you put the start of the line in (pay attention to how you pull out the old line and put the new line in the same way you took out the old line), then just assemble back together and make sure you pull 3-6 inches out through the line holes on the barrel before final assembly and you should be good to go.
If that doesn't work for you, then take it to your local home depot or lowes or lawn and garden hardware store and they will most likely just show you real quick how to do it in person, should be free unless their greedy:)
Jul 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
May 07, 2008 | Black & Decker String Trimmer Cordless 12"...
Braun Syncro 7680 Electric Razor
Great instructions.
I left out the plastic latch and the razor works fine. OK with me.
On step "f" there was a little guide on one side...I had to push that in before sliding the switch upwards...it slid right out after doing that.
Thanks...it helped a lot.
Jan 24, 2008 | Braun Syncro 7680 Electric Shaver
Garden Logo
469 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
