Question about Ariston Technologies Dishwashers
Ariston ls1072. water going straight through the system. seems a valve is not operating.
    Scholar:
  • 61 Answers
Sounds loke the drain is lower than the machine, is it new install or been moved recently? try raising the drain hose middle section a foot or two above the ground.
Posted on Jul 23, 2009
Water runs in and straight out of my washing machine
drain pipe has to be as high off floor as the washer is tall .
Jan 30, 2016 | Washing Machines
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
L 63 B NA Ariston
detect any operating anomalies. These anomalies are reported by
one or two wash cycle indicator lights "G" flashing rapidly.
24238319-0h3kxpflbez5mdeb5anq3st4-3-0.jpg In this case could be:
  • Drain motor disabled
  • Filters clogged
  • Drain hose blocked
Dado
Apr 24, 2014 | Ariston Technologies Dishwashers
I have an Ariston 640 LI dishwasher and no water seems to be flowing into the dishwasher
hi there Mellisa, Is the tap turned on? if it is in may be the inlet valve at fault you will need to have it checked it see if the valve is recieving the open command from the controler. let me know if this helps, regards
Gary
Oct 16, 2011 | Ariston Technologies LI640S Dishwasher
The 4th green light on my Ariston dishwasher flashes. What does this mean?
You did not mention what model number that you had but this is what I found after a little digging:
From http://servicetechhelp.com/discus/messages/2801/6823.html?1205974228 :
For future reference, the technician who replaced the control board for me gave me a complete list of flashing LED fault codes for the Ariston LL65 (which are same as Ariston LL64):
001000 Float Switch: Water in Base Pan
001100 No Drain: Dranin Motor Disabled, Filters Clogged, Dramin Hose Blocked
001010 Main Motor Presure Switch Blocked Filter
100100 Control Board: Software of Control Board not Recognized.
000100 Water Valve: Water Valve Diabled <--- This one sounds like your error
000110 Fill Fault: Water Valve Disabled, Turbine Disabled or Control Board
000101 Heating Element disabled or High Limit Open or Control Board
000010 NTC defective or not positioned or control board
000001 NTC defective or not positioned or control board
KEY: 0 = LED off
1 = LED flashing
I also found this for a different model:
http://www.diybanter.com/home-ownership/89945-resetting-controller-ariston-dishwasher.html
No Program Code Fault condition
1 Heavy wash 1000 Operation of flood
protection system
2 Normal wash 0100 Heating
element/Thermistor/Thermostat fault
3 Rapid wash 0010 Drain pump fault or drain
blockage
4 Soak wash 0001 Not filling to correct
level within 6 minutes
Mar 02, 2011 | Dishwashers
Hi my ariston a1636 doesnt seem to pump water out it is now full to the brim and wont open the last two or three washes water came seeping out the draw is there a blockage in my pump
Could be but think more of an overfill fault cased by a blockage @ the pressure switch this controls the level of water in the drum shutting off fill valves. The pressure switch or air switch operates at 3 psi it is round with wiring onto it and has a tube connected to it ....make sure the Tube and chamber tat feeds this is clear as this is common to fail the valve and result in overfill,Apart from a faulty fill valve of course, this should cut off when power is removed.....good luck
Apr 15, 2010 | Ariston Technologies AWD121WH
I am not getting any hot water, only cold water, when I run my hot water taps. I have an Ariston Bravo water heater. Normally I have permanent hot water at any time. My central heating seems to be...
Sounds like the by-pass valve diaphragm. This valve detects that hot water is being drawn off at the tap and then diverts the mains input water across the heat exchanger. Very often it's the diaphragm inside the valve which is punctured or split.This can be replaced [depending on model] if you take apart the valve
. Remove the front panel and lower the control panel.The valve is at the bottom left of the boiler
Suggest turning off the service taps to the two heating pipes and the cold mains inlet pipes before tackling the valve
Mar 20, 2010 | Water Heaters
Water doesn't go in and he couldn't see what is wrong with machin
i would take a look at the inlet water screen on te water fill valve and be sure thatits cleared. look where the water goes into the unit and that is where the valve is and screeen is going to be where the water goes into the valve.
Jan 01, 2009 | Ariston Technologies L63 Free-Standing...
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
Dishwashers Logo
110 people viewed this question
Top Ariston Technologies Dishwashers Experts
Electro Med Services...
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
