Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice Build Up in Freezer of FRS26ZSH
I have the exact same problem - same model FRS26ZSH - ice building up on bottom of freezer, defrosting and leaking out freezer door onto kitchen floor. I'm afraid I can not see what the "solution" to the problem was. Thanking you in advance for your assistance!
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Posted on Aug 02, 2009
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Whirlpool Side by Side Freezer - Ice Build Up in Drain
After the drain thaws , ( I use about a 4 inch aluminum fence tie or if need longer , aluminum wire with no insulation ,) insert it into the drain hole as far as it will go with no force , and wrap the top end about 1 turn around the calrod defrost heater , This transfers heat to the hole so the ice will not freeze up the hole . Before doing this step , use a hose and blow into the drain to possible clear out any debris which could have accumulated in the drain trap .
Jul 21, 2009 | Whirlpool GC5THEXNS Stainless Steel Side...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a whirlpool Gold Model GR2SHKXKS01. My problem is ice build up under the bottom tray of freezer and when fridge defrost the tube is frozen solid and creates this build up. After cleaning all the ice...
I have Ice build up under the tray in the freezer which makes water run into my refig and makes a mess what would cause this is the evavorator motor out?
Jun 03, 2009 | Refrigerators
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Fridgidaire frs26zsh side by side ice buildup in bottom freezer
if you have icemaker install check there or you have a clogged in your drain cut ashort piece of naked wire wrap it on the heater coil and puch wire down in drain not a long piece please unplug refrigerator
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire #FRS26ZSH : Fresh food not even cool.
that is a defrost problem need tech to one of a few possible problems you can defrost unit completely for 2 days and it will work great for a week or so
Feb 07, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator and freezer not cooling. We checked out the door, and that seems to be fine. There is some ice build up on the bottom of freezer and on back panel. Model # is FRS26ZSH Thanks.
sonds like a either a defrost issue,( not self defrosting), or your evaporator fan motor is not turning,can you here hte fan turning inside the freezer compartment???
Nov 24, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
479 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
