Question about Asko Dryers
Asko Dryer T711 relay chattering near the end of a cycle I
Asko Dryer T711 usually near the end of a cycle I have what sounds like a relay chattering. Goes on for a few seconds then stops for a minute or so and starts chattering again.
Thanks,
Larry
    Scholar:
  • 61 Answers
Relays only have a specified life of x amount of switches x depending on the style and manufacturer, so there is a good chance it will fail eventually, if you know someone technically minded you could get them to change the relay which would be cheaper than the board its fitted too, as its at the end of the cycle i would guess it controls the heater as it cools down near the end to stop you buring yourself on the drum.
Posted on Jul 23, 2009
Asko T711 Dryer
Most often the top panel is the first to be removed, a couple screws in the back and then lift and slide forward. That normally gives access to view how the rest of the puzzle went together.I changed bearings on my Crosley and never did move the front cover. This might give you a place to start while waiting for a better answer.
Jan 06, 2014 | Asko Dryers
Asko t711 dryer
you have to remove the front of the dryer usually by popping the to top and then removing the 2 screws into the front ring the belt strong around the drum, around the tensor and around the motor. it doesn't go around the wheel of the tensioner but it just puts tension on the belt like pushing it to user up the slack
Feb 01, 2012 | Kenmore Dryers
I have a T711 asko dryer. When I push the start button it makes the sound when the dryer has completed its cycle. There is a "signal" button that you can depress to let you know the dryer is finishe
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Nov 11, 2011 | Asko T711 Electric Dryer
Where is the thermostatelocatedonthe asko t711 dryer
Welcome to FixYa.
To answer your question, it depends on which thermostat`s it is you`d like to know about.
Attached below is the location of the cycling thermostat`s and below that is the location of the reset-able safety thermostat. It is on the back wall under the black rubber cap I`m pointing at in the 2nd photo.
Cycling in front blower
Hi-limit reset-able thermostat.
Hope this answers your question, but let me know if you need anything else...I`ve got more info on the Asko washer, dryer, and dishwashers.
Thanks for choosing FixYa. Please take a moment to leave a testimony and rate the info I provided.
Good luck.
Regards,
Macmarkus :)
Sep 07, 2010 | Asko T711 Electric Dryer
My wasmachine (asko 10625) doesn't spin at all Not
either motor winding is failed or motor brushes or no power to motor. needs to be tested with a multimeter
Jan 31, 2010 | Asko T711 Electric Dryer
My ASKO T702C dryer just stopped working. It starts but after 5 mins it just turns off. Any suggestions?
Try opening the bottom vent panel and pulling out the filter box (there are directions and handles)... hold the filter under running hot water for a while and you should see all this nasty stuff come out. Worked for me!
Jun 11, 2009 | Asko T711 Electric Dryer
Wrinkly clothes
Here are a few tips to combat this issue.
•Select a shorter drying time.
•Remove items while they still hold a slight amount of
moisture.
Remove items when cycle ends and fold or hang
immediately.
This will prevent wrinkles.
Feb 21, 2009 | Asko T711 Electric Dryer
Asko Dryer model T-701
you need to replace the motor you can replace the rear half of the motor but you can only buy a complete motor.this isnt a common problem but i have had it before.it broke because you need to grease the pin every 5 years or so.
Oct 24, 2008 | Asko T711 Electric Dryer
Dryers Logo
227 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
