Question about Brother LS-2125 Mechanical Sewing Machine
My sewing machine will not perform the zig-zag sewing function.
I am in the process of sewing cushion covers made from scotchguard fabric and I am tidying the edges by performing the zig-zag function. I changed the necessary controls etc but it still stitches straight. What should be done to rectify this problem??
  • albranch Jul 23, 2009
    Thanks for your prompt response, I will get on it this evening and let you know the results.
    God Bless You Too!!!
    Brigadier General:
  • 3,513 Answers
Hello
Thnx for contacting Fixya.
plz try these steps to perform zig-zag stiches in your sewing machine..
Choose the type or width of zigzag stitch you want to use. Fairly wide zigzag stitches are useful for finishing the edges of seams, while narrow zigzag stitches work better for small pieces of fabric and for appliqués.
  • Turn the hand wheel of the sewing machine toward you until the needle is in the fully raised position. If you try to change stitch types with the needle lowered, the needle may break.
  • Set the sewing machine stitch to the type and width of zigzag stitch you want. Some sewing machines have a manual dial for the stitch types, while others use electronic stitch controls.
  • Adjust the stitch length to match the type of zigzag stitching you need. A regular stitch length works fine for finishing the edges of fabric to keep them from raveling. But for appliqués, you may want to use an extra short stitch length to make the zigzag stitches closer together.
  • Set your sewing machine speed to slow for zigzag stitching appliqués and small pieces, or leave it on normal or fast for long, straight seams.
  • Test the zigzag stitch on a scrap of fabric. You may want to use a contrasting thread color for the test so you can see the stitches more easily. Once you have a zigzag stitch width and length that’s appropriate for your project, you can stitch your real fabric using matching thread.
  • Raise the needle and adjust the type or width and length of the zigzag stitch if needed.
  • Zigzag stitch along the cut edge of a piece of fabric so that the edges of the zigzag stitch come as close to the edge of the fabric as possible, without going off the edge. If the zigzag stitches are too far from the edge, the fabric with ravel up to the zigzag stitching.
  • Zigzag stitch appliqués or layers of fabric so that the zigzag stitches overlap the edge of the upper layer. About half the width of the zigzag stitch should be on the appliqué or trim, and half of the zigzag stitch should be on the fabric below.
  • OR
    here are a few more tips..
    check to see at what width you've set the overlock - if it is at the very extreme, bring it back a notch. sometimes, the extreme settings cause errors/untidiness.
    have you changed fabrics? does the error occur in any/all types of fabric? if it works fine on some fabrics but not on others, here's a very handy tip :
    place strips of newspaper or kitchen roll under the stitching line under the fabric. this enables the smooth movement of fabric & neat, even stitches. after you've finished, just rip off the paper .
    check to see whether all the parts of the machine are intact, no breakage inside. oil your machine.
    and check the tension.
    hope i ve tried to give a satisfactory answer.
    If u ve further quearies and confusion plzz do let me kno,we will b happy to help you.
    all the best
    God bless
    Posted on Jul 23, 2009
    What stitch should I use to sew stretch cotton fabric
    Hard to tell because your machine is unidentified.
    Jul 14, 2017 | Sewing Machines
    When i use the zig zag stich, sometimes the stich falls and does not zig zag
    try a new needle--one for the fabric being sewed
    could be a problem with the cam that does the zig zag, you might need to have the machine checked
    if your sewing with light weight fabric also try using stablizer
    Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
    Elna machine puckers silk on zig zag stitching, Elna 2007
    Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
    Jul 07, 2015 | Elna Sewing Machines
    I dont have the instruction manual and i cant figure out how to do a zig zag stitch? Help
    You don't say the make and model of sewing machine. But generally zig zag is achieved by selecting the zig zig stitch on the stitch selector, then setting stitch length to 2 and stitch,width to between 3 and 4, depending on the fabric. If its a very light weight fabric 4 the thread will pull in and tunnel the fabric so turn down to narrow the width of the stitch.
    Mar 03, 2015 | Sewing Machines
    Raw edge zig zag stitch bunching underneath
    When zig zagging over a raw edge, the tension on the thread will pull in the fabric, especially in lightweight cottons or even lighter organza. Its not the best edging method for very light weight fabrics. You can try using a smaller zig zag, loosening off the top tension a little bit. Or if your machine has it, use the triple zig zag or serpentine stitch, where the needle goes through the fabric three times to make up each zig stitch, this stitch is better for edging most fabrics and is my preferred stitch.
    Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
    Zig-zag settings
    you probably shouldn't be using a zig zag for that application. But the multi-stitch zig zag.
    Please look at page 40 of your manual for information.
    As for needle breaking check to make sure your need is the correct one for the thread and fabric. Also make sure your pressure foot is the one recommended for the stitch. Consider this... most thicker fabrics require a longer stitch.
    Aug 21, 2012 | Singer Confidence 7463 Computerized Sewing...
    Trouble sewing lycra fabric using a zig zag stitch
    You have the machine set for blind hem stitching. Change the stitch selector to stretch stitch, which is a single, in line stitching zig zag stitch.
    Cheers,
    Embroidery Services
    San Diego, CA
    Sep 13, 2017 | Sewing Machines
    My singer does'nt do dverlockWhat can I do ?
    No sewing machine does a true overlock stitch, that is what sergers are for, they trim and form a stitch on the edge of the fabric using 1 or 2 needles and two loopers. Costs more for an additional machine but the finish is much more like a shop bought item.
    tally_girl_14.jpgi
    Some sewing machines have an overcasting or interlock stitch which looks like stitch 10 in this picture above. Your machine may have this stitch?
    If not, does it have a three step zig zag? It looks like a zig zag but the needle goes into the fabric three times as it forms each leg of the zig zag. This stitch is great for neatening a raw edge and I use this a lot myself. Especially on wovens as it is always faster to seam with this rather than the overcasting stitch where the feed dogs move the fabric forwards, then backwards, then forward to make the stitch.
    The sewing machine made overcasting stitch can be used to sew knit fabrics, attach rib around an neck line and neaten raw edges but it is always going to take longer than a serger and there is no trimming function so its never going to look like a shop made overlocked item. However, you can sew knit fabrics with a sewing macine with a bit of patience as long as the machine has some "Forwards/backwards" type stitches as these put elasticity into the seams - if you seam knit with a straight stitch, seams can break when under tension during wear.
    And use a twin stretch needle and straight sttich to sew the hems, this looks a bit like a cover stitch and has a bit of give in it too.
    Hope this helps you a little. You can find some good sewing general info on www.sewing.about.com or invest in a good sewing book. I refer to my Vogue Sewing Manual and my Singer Sewing Secrets often. Or take a sewing class, its a great way to learn new things, get enthused and have fun.
    Apr 08, 2011 | Singer 3116 Simple
    My machine sews straight when set to zig zag and skips stitches sometimes. It zig zags but only gets half the stitch.
    If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
    Dec 12, 2010 | Brother LS-2125 Mechanical Sewing Machine
    I AM MAKING FABRIC BOWLS WHICH CALLS FOR ZIG-ZAG AROUND THE TOP EDGE AND ON THE DART THAT MAKE THE FLAT FABRIC SANDWICH (FABRIC/STIFF INTERFACING/FABRIC) TAKE ON A BOWL SHAPE. MY MACHINE ZIG-ZAGS, SKIPS,...
    you may want to try a bigger needle that helped me with mine. let me know if this helps. i have the book on fabric bowls will look for more thing to help you.
    Dec 22, 2008 | Janome Memory Craft 9000 Computerized...
    Brother LS-2125 Mechanical Sewing Machine Logo
    448 people viewed this question
    Top Brother Sewing Machines Experts
    Tally Girl
    Tally Girl
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
