Question about Refrigerators
Side by side frezer frezes up icebox side won't stay cold until manualy thaw fezer side the icebox side cools for a few days.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sound like a timmer and a thermostat to me
we have had the same problem from time to time usualy we just change the thermostat out and problem solved
remember to unplug the fridge for a 24 hour period to de thaw the baffels in the fridge after you change the thermostat
also check your drain lines in the back they might also be pluged
another words wrap your lips arround the pipe in the rear of the fridge and blow if there is back preasure then you probably have a blockage
Posted on Jul 23, 2009
The fridge is not working.the freezer is working.in the freezer the cold air is not coming in the fridge.
fridge basics
the fridge and freezer are seperate compartments they dont share air there is a chemical filled filiment on your fridge u can see it at the back looks like a big grill that chemical is pumped around both fridge and frezer that chemical carrys heat energy it removes the heat from the fridge and frezer to the radiator at the back this radiator gets verry hot whyle your fridge / frezer becomes cold it shuld be 1 compleate system with better fluid flow in the frezer to make it cool faster
ok so the frezer is working but fridge is not it could be a few things 1 fluid not geting round the fridge lack of fluid or 2 a blockage
im no expert but knowing the basic science of fridges is a help i hope this has helped but like i say im not farmiliar with any fridge and models deviate but the science stays the same hopefully this steers u in the right direction
Oct 30, 2012 | Refrigerators
Freezer is frezing but refreg side is not staying cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 03, 2011 | Refrigerators
I have a GE side by side Model No. GSS25JFMCWW. The refrigerator side is not staying cold. When I remove the back panel in the freezer there is heavy frost build up on the coils. If i thaw out the coils...
the ice disp stopped working now the unit will try to start then stop over and over, went to main board on back of frig. took off jumper one connector it stopped but not sure what jumper one controls
Oct 26, 2010 | GE GSS25JFM Side by Side Refrigerator
Ge model # tff34rvf refrigerator runs then shuts off for a long time. frezer makes ice and frezes items then things thaw agan
run times are to long . caused by dirty cond coil or fans running too slow . clean coil first this may correct problem . if not , the the cold control may be failing so replace it next .. and clean it reg . as it will nt cool when dirty .. mm
Jan 07, 2010 | Refrigerators
FRIDGE THAWING
pull your refrig away from the wall and check to see if your compressor is running i'm willing to bet that the start relay is bad you will here a humming and then clicking noise approx every 3-5  mins. its a very easy repair get part number 8201786 from whirlpool it has detailed instructions and should only cost you 40-60 dollars for part.
Jan 22, 2009 | Whirlpool Refrigerators
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore Refrigerator Model #25357677791
stuck defrost timer/ thermostat. id go with both stuck because I'm looking at a diagram of your fridge now and there wired together.
i'd recommend changing both of them.
hope to be of any assistance.
Apr 26, 2008 | Refrigerators
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
