Cell Phones Logo
d
deborah Parker Posted on Mar 06, 2017
I need to follow up on my activation case #662232. I tried to activate my phone yesterday was on it from 8:30 am till 2:30 or so. My phone is still not activated
512-415-3102 is my number that is not activated. I am bringing my phone from Sprint
I am trying to find out how to keep my old number and activate this new phone
your number needs to be active,do not shut it off till you do this,find a service provider you like,ask them if they can transfer your number,buy the service and have them activate your new phone,they will need to know who your old number is with,because they need to contact them
Jun 18, 2015 • Cell Phones
6helpful
Nokia x2-01i need suncellular configuration for my x2 i need to open my internet browser
Phone Configuration Guide
1) To activate your GPRS and handset settings, text ACTIVATE to 2300.
2) In case you are unable to receive handset settings, you may choose to configure your handset settings manually. Please select your handset model in the drop down list below and follow the instructions in the file.
http://www.suncellular.com.ph/ecs_configure.php
Jun 18, 2011 • Cell Phones
How to take your phone off silent
Hi traceylachla ,
Depends on the phone you are using , however generally there is way to remove your phone from silent mode as well as activate silent mode , please follow the below steps :-
  1. When in idle mode, keep the # key pressed till the time it tells you general profile has been activated or normal profile has been activated.
  2. If you press the # key again for a bit long time like 2 to 5 secs it will again go to silent mode.
Hope this trick helps you...:)
4answers
I dont now how activate the window 7
Click the Start button (Orb in the lower left hand corner of the screen). RIGHT click on Computer and select Properties from the menu. At the bottom of the window you will see the Windows Activation section and an option to Activate Windows Now. Click on it and the activation dialog screen will appear.
1helpful
How to open the GPRS of chinaphone
creating data accounts:
Steps:
1. Open Services Menu.
2. Open Data Account.
3. Open GPRS.
4. Create/Edit Data Account and enter the following values:
For Globe MMS Data Account:
Account Name: GlobeMMS
APN: mms.globe.com.ph
User Name: leave it blank
Password: leave it blank
Auth. Type: Normal
For Globe GPRS Data Account:
Account Name: GlobeGPRS
APN: http://www.globe.com.ph
Auth. Type: Normal
For Smart MMS Data Account:
Account Name: SmartMMS
APN: mms
Auth. Type: Normal
For Smart GPRS Data Account:
Account Name: SmartGPRS
APN: smart1
Auth. Type: Normal
5. Save the Data Account.
Configuring WAP/GPRS/Internet Services Using the Data Accounts Created
2. Open WAP.
3. Open Settings.
4. Open Edit Profile.
5. Create/Edit a Profile and enter the following values:
For Globe GPRS Profile:
Rename Profile: myGlobe GPRS
Homepage: http://www.globe.com.ph/globe.asp
Data Account: GlobeGPRS (this data account is the one you have created)
Connection Type: HTTP
Proxy Address: 203.177.042.214
Proxy Port: 8080
Username: leave it blank
For Smart GPRS Profile:
Rename Profile: SmartGPRS
Homepage: http://wap.smart.com.ph
Data Account: SmartGPRS (this data account is the one you have created)
Proxy Address: 010.102.061.046
Proxy Port: 8080
6. Save the Profile.
7. Activate the Profile.
8. WAP/GPRS/Internet services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
Configuring MMS Using the Data Accounts Created
1. Open Messages.
2. Open MMS.
3. Open Message Settings.
4. Open Server Profile.
For Globe MMS Profile:
Rename Profile: GlobeMMS
Homepage: http://192.40.100.22:10021/mmsc
Data Account: GlobeMMS (this data account is the one you have created)
Proxy Address: 192.040.100.020
Proxy Port: 8080
For Smart MMS Profile:
Rename Profile: SmartMMS
Homepage: http://10.102.61.238:8002
Data Account: SmartMMS (this data account is the one you have created)
Proxy Port: 8080
8. MMS services now ready to use. In case you encounter errors, double check the Data Account and Profile created. In some cases you need to restart the phone.
This configuration is working perfectly using ZT321, Baizhao 8928 and IPhone Clone A380 and probably will work using other China Phones.
If your SIM card is previously activated using other phones specially those phones supported by Globe and Smart, no need to activate your SIM. This is also valid for postpaid users since SIM cards are pre-activated for MMS, GPRS and other services.
But if your SIM is not yet activated or never been used for MMS and GPRS, you need to activate your SIM before you can use MMS and GPRS services.
For Smart SIM, you can use your China Phones to activate MMS and GPRS by simply sending/texting MMS ON / GPRS ON to 333 (I don?t know if this number is still valid). No need to download the configuration for Smart. Just use the configuration I?ve given.
For Globe SIM, this is a little bit harder and need some workaround. I tried to call Globe Customer Service but they cannot activate your SIM manually on their system and the only way to activate it is by downloading the configuration thru text or by asking them to send the configuration. But since China Phones are not yet supported by any Service Provider, what you can do is to active MMS and GPRS using another phone. Monitor until your SIM is activated then transfer your SIM in your China Phone and enjoy surfing and sending MMS.
In another forum, they said you can try using configuration for SE p900. I?ve never tried this but if this really works, well and good for China Phone fanatics.
1helpful
Activaion KEY NEEDED BAD!!!
Unfortunately we can't give you a product key or activation code to activate the operating system, on Microsoft can do this.
The product key should be on a sticker underneath the laptop, use this key to activate the laptop. If it won't allow it you will need to activate by phone, tell Microsoft that you had a hard drive failure and they will activate Windows for you, just give them the code you have posted and they will walk you through the activation by giving you another code to input.
Have a pen and paper ready to write down the code.
How to activate Windows XP by phone loadTOCNode(2, 'summary'); To contact a Microsoft customer service representative to activate Windows by phone, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, I want to telephone a customer service representative to active Windows now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Follow the steps in the Activate Windows by phone dialog box, and then click Next.
    Note The number appears now and differs based on the location that you select.
  5. When activation is completed and you receive the following message, click OK. You have successfully activated your copy of Windows.
Good luck.
2answers
Cannot connect to the internet following activation of XP
did you activate the Windows Xp when you installed the XP Operating system?
you have 30 days to activate the XP, if not you will have limited use till you input the genuine serial key.
if the display changed after the activation, chance are you machine have being hijacked.
I would just take it off line and try to clean the infection.
1helpful
Bluetooth problem
pls check that the bluetooth visibility is off or on
Motorola V120 c
I have the same problem- Yesterday I bought my second hand and the phone number wasnt programmed into the phone either. Try doing it like this 74663# press menu and press menu again it should bring up the user activation
Top Sprint Cell Phones Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
