Question about Canon imageRUNNER C3200 Copier
Toner cartridge wont come out.
I have c3220 I removed a toner cartridge thinking I could turn from side to side as diagram on cartridge depics and shake up toner to continue use of present cartridge because I presently did not havew a new one. Cartrage slid back in but would not completely join with unit as before, now cartridge will not come all the way back out to replace with new.
  • tracy_willia Jul 27, 2009
    I called a repair man, I'm not sure exactly what he described because I was in a meeting when he left and our talk was brief, but I quess something in the chamber which the cartridge slides into was blocking the cartidge from entering all the way or being removed. It required him to remove the locking cover that held all toner cartriges in place, to fix the problem. Thanks anyway.
  • 149 Answers
Try removing the corresponding drum unit below it first. If you remove the waste toner bottle you will then be able to pull down the plastic handle and drop the small door that covers the four drum units. Try and remove only the same colour as the problem toner first. Now try and push the toner back in and then remove it. After, slide the drum unit back in. Good luck
Posted on Jul 25, 2009
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
How to insert a cartridge in canon printer 4320d ?..
Hold the front side of the operation panel with your hands.
Lift the scanning platform (A) until it is locked. (You will hear an audible "click.")
Hold the grip (A) on the right front side of the toner cover.
Take out the new toner cartridge from the protective bag.
Do not open the drum protective shutter (A).
Save the protective bag. You may need it later when you remove the toner cartridge from the machine.
Gently rock the toner cartridge several times to evenly distribute toner inside.
Place the toner cartridge on a flat surface and pull the seal completely out.
If toner is adhered on the removed seal, be careful that your hands or clothes do not get dirty from touching the toner.
Do not pull the seal out at an angle.
Hold the toner cartridge by its handle (A).
  • Do not open the drum protective shutter on the toner cartridge. Print quality may deteriorate if the drum surface is exposed to light or is damaged.
Always hold the toner cartridge by its handle
Insert the toner cartridge so that the protrusion (A) on the right side of the toner cartridge fits into the guide (B) located on the right side of the machine and slide it down parallel to the guide.
Push the toner cartridge to make sure it is properly set in the machine.
Close the toner cover.
Lower the scanning platform.
If you cannot close the toner cover, do not force it to close. Open the cover and make sure the toner cartridge is properly set in the machine.
Be careful not to get your fingers caught.
Dec 04, 2010 | Canon Office Equipment & Supplies
How do i change the toner on this copy machine?
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
Sep 24, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jun 24, 2010 | Brother HL 5250DN Laser Printer
Toner light is on and it wont print
The toner light being on solid means that the toner cartridge is empty.
You will need to replace it with a new one.
When replacing the cartridge, please remember to seperate the toner and the drum, DO NOT THROW OUT THE DRUM.
If you have already changed the toner cartridge with a new one, then you will want to reset the toner cartridge.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 07, 2010 | Brother HL-2170W Laser Printer
Best place to buy toner
ebay 1st i can alsosuggest southeastern wholesale when they have some ask for darryl 931-268-6601
Dec 31, 2008 | Canon imageRUNNER C3200 Copier
Error code 000019-0000
Hi Jeff the Error code for tha model is for the waste toner bottle. The waste toner bottle is located on the left side of the copier toward the rear of the copier. It is to the left of the fixing unit door / where you pull a jam from the fixing unit. It is held in by one screw. Remove the cover and you will see the waste toner bottle. Remove it and you may think it is not that full. The problem is that the neck of the bottle gets waste toner on it and it blocks the sensor. I would empty out the bottle in to a garbage bag and tie the bag up, as to not make a mess. Then make sure the neck of the bottle is spotless of toner then reinstall and turn the copier Off then back On and remove the paper jams and you are done.
Jul 12, 2008 | Canon imageRUNNER C3220 Color Copier
Toner
Push up on the release latch on the Right Side Cover to open the cover
  1. CAUTION: Ensure the side cover is always open before opening the front cover.
  2. Open the Front Door.
    Turn the orange Toner locking lever up to unlock the Toner Cartridge.
    Pull the Toner Cartridge out of the machine.
  3. Remove the new Toner Cartridge from the box. Save the box and the packaging for storing the old cartridge.
  4. Gently shake the new cartridge horizontally 4 or 5 times to loosen the toner. Be careful of any Toner spill.
    NOTE: Shaking the cartridge will ensure maximum copies per cartridge.
  5. Slide the new cartridge into the machine until it locks in place
  6. Turn the Toner locking lever down until it locks in place.
    IF it is not sliding in. remove the cartridge and on the back of it, there is a round drive you may have to spin a quarter turn and reinsert. Sometimes that doesnt line up
May 19, 2008 | Xerox FAXCENTRE 2218 18PPM FAX
HP Laserjet 1022
Have you refilled the toner cartridge or is it refill as when these toner cartridges are refilled they have a tendency to leak. I suggest to remove toner cartridge turn the machine off vacuum out the inside and replace the toner cartridge with a new original. Run 20-30 prints through to get rid of any other loose toner and then should be fine.
If printing doesn't improve then repeat process if still same problem suggest transfer roller to be changed.
Hope this helps
Thanks J
Nov 15, 2007 | HP LaserJet 1022n Printer
Canon imageRUNNER C3200 Copier Logo
95 people viewed this question
old marine
old marine
