Question about Garmin Nuvi 660 GPS Receiver
Garmin 650 won't hold charge in car -- same problem
I contacted Garmin and they sent a replacement battery. Problem still persists. I have all but given up using the device. I don't know if the problem is in the male end connection (that goes into the lighter) or the female end on the mounting cradle (in which the unit sits) or the male end on the cord that attaches to the cradle.
All I know is the unit drains quickly when used in car, apparently without receiving any charge from car.
Any suggestions?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Garmin probably sent you another car adapter/charger, not a battery, as the battery is non-user replaceable (requires the unit to be taken apart). It could very well be a problem in the cradle or the cradle connection at the rear of the Nuvi. Like the previous comment, make sure you have +12VDC at the lighter socket. When you have the proper external voltage charging the battery, you should see a "yellow" lightning bolt appear over the green battery bar graph display on the main menu. if you don't see that, the battery isn't being charged. What about with the AC wall charger? Can you charge the unit with that? It would plug into the side mini-USB connector. Do you see the yelllow lightning bolt there? Here's some more info you can read about:http://www.sharc.net/gps_charger_repair.... - Jim
  • 118 Answers
Check power at the 12volt outlet to insure that you power is on at the connection. Try using a 12 volt convertor in the house to check the cord used in the vehicle.
Posted on Jul 23, 2009
Does`t seem to charge w/USB, in car after two hours only get 4 batteries is this normal?
Mine does the same thing, after years of freezing heating and thawing in the car the batteries just won't hold a charge anymore.Getting a replacement battery would cost about $24 plus shipping.
http://www.amazon.com/Garmin-Nuvi-750-Installation-010-00583-00/dp/B000UGPHI4
It is possible to change the battery yourself.
http://www.youtube.com/watch?v=qXXzsi9Ures
TickMagnet
Aug 15, 2011 | Garmin nuvi 1300 Car GPS Receiver
Garmin gps powers off even when fully charged
If you're "recharging" via the car charger - you might want to try charging via USB jack on your computer - or AC adapter (if your GPS shipped with one) for 5 or more hours.
Many Garmin units develop this condition when used strictly in the car / cigar outlet power source. While connected to your computer, you should go to Garmin's website and download, install & run the "webupdater" software. When complete, your Garmin GPS will have the latest firmware and patches to the software (not maps!).
After charging via USB or AC adapter, your GPS should stay on. If your GPS turns on via a slide switch on the top, Slide the switch from OFF and hold in the ON position for 10 seconds before letting go of the switch. This should force a "boot" on the GPS.
If you're unable to get the device to power up, contact Garmin Support to determine if your device is affected by a a recent battery recall or if there are other suggestions they have to solve the problem.
I hope this helps!
Oct 08, 2010 | Garmin nuvi 650 GPS Receiver
This device will not charge. It was being hard wired into the ignition, two wires touched... sparks. Now it won't charge...?
Sparks from a battery operated device is never a good thing. The device might need to go back to Garmin for repair, but before you send it back - try the steps below first.
From Garmin's website:
  1. Make sure you are sliding the power button all the way to the left.
    • If the unit does not respond, it may be that the battery is not charged.
  2. Connect the nuvi to a power source such as the USB cable and your computer.
  3. Reset the device, if the problem persists, by sliding the power button to the left and holding it in that position for 10 seconds
    • This resets the unit and prompts it to power on
If it still won't charge, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck!
Jun 25, 2010 | Garmin Nuvi 760 Car GPS Receiver
My Garmin Nuvi 760 screen goes black after 8-9 seconds. I have replaced the fuse in the charge cord. Someone recommended that I remove the battery and turn the power button on for ten seconds to reset the...
Do not open the nuvi, the garmin site recommends the following method instead:
If this fails to solve the problem, contact "SUPPORT" at www.garmin.com.
Please rate this reply if helpful - good luck.
Jun 20, 2010 | Garmin Nuvi 760 Car GPS Receiver
My GPS shuts itself off even when fully charged
Typical issue with a defective battery. It's not holding a charge and needs replaced. Please see this link:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Apr 29, 2010 | Garmin nuvi 650 GPS Receiver
How do I replace the battery for a garmin nuvi 650
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Dec 12, 2009 | Garmin nuvi 650 GPS Receiver
How do I open Garmin nuvi 650 to replace battery?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Are you sure you have a dad battery?
MAKE SURE to use a Garmin charger!!!!!!
Nov 10, 2009 | Garmin nuvi 650 GPS Receiver
My Garmin Nuvi 200 won't turn on/fully charged
If it is not charged it will not turn on. If you have a bad battery (which is the case if it won't fully charge) your only choice is to return to Garmin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device. Go here for repair:
http://www8.garmin.com/support/outofwarranty.html
Aug 12, 2009 | Garmin nuvi 200W GPS Receiver
Replacing battery in Garmin Nuvi 650
I discovered a video on how to replace the Nuvi 650 battery. Hope this helps, Rob
Feb 15, 2009 | Garmin nuvi 650 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
778 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
