Back to:
Tags:
Nikon LS 2000 Film Scanner
Hardware error (by 2 users)
posted by jslack on Nov 20, 2007
Problem:Slide no longer feeds. It seems to want to run, but then comes up with hardware error and won't function.  Running on OS Mac 9.2
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by 2thsavr, posted on Dec 15, 2007
After a lengthy and expensive visit to the Nikon Shop a while back my LS 2000 was returned as non-functional as the day I sent it to them, (the hardware error message "sense ......" I'd given up on it and was just about to purchase a new scanner. Then I found the suggested fix involving the little brass screw in the gear on the bottom front. Technically challenged as I am it only took me 11 minutes to effect the repair. I gave the screw one turn counterclockwise to start. It worked. Not only will it scan but it does so quietly and with autofocus that is precise and autoexposure that is as near to perfect as I can see. Thanks
Best Solution
posted on Dec 03, 2007
FixYa! (100)
kklutz
Rank:Apprentice Apprentice
Rating: 95%, 6 votes
the problem is that the scan sledge gets stuck if arriving at end of screw. To fix:
Open scanner by unscrewing the four screws in the back - this will allow ypu to slide the sides slighly backwards and then remove. Then take the plastic front of (press the plastic tap on top with screwdriver). You will the see a small brass screw center bottom at the front. Loosen this a few turn and try again (you may have to try a few times)...
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hardware error:
I don't want to Accept this solution
Can you Help with these Scanners problems?
Scanners
Hello, My film scanner Minolta 5400 II shows strip line on...
Scanners
I used my fathers scanner to scan my military service and...
Scanners
The 12 volt motor that drives the scanner has stopped...
Nikon LS 2000 Film Scanner (35 mm)
I recently cleaned and lubricated my Nikon LS-2000 since...
I recently added a SF-200 loader to my operational...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
