Question about Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT
Jandy Lite2 Pool heater will not stay lit after firing
We just purchased the lite2 a week ago and it is doing the same thing. We found out by accident that the gas pressure is too high. The cap was off the drip leg and the heater lit and stayed on. If you turn down the regulator to 2 it will continue to run. However it will take forever to heat up. Our technician is still trying to get a hold of Jandy tecnical but it's a min of a 30 min wait time. It seem that the FL2 problem is common with the Lite 2. Once we find the problem or if anyone else hears of a solution it will be posted.
  • 990 Answers
If your persure is to high you are probally running propane in a natural gas heater. If this is a new heater take it back and get a new L.P. verson if not they make a conversion kit with new gas orfaces for the burner and a new gas block for the gas valve. if your tech dosen't know this get a new tech, this is a box full of fire next to your hause. Don't save money on the tech it can cost to much!
Posted on Oct 05, 2009
Jandy lite2 pool heater
shorted temp sensor un plug the two black wires on control board should stop flashing if it does replace temp sensor
May 24, 2013 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Jandy lite2 lg175 pool heater will not remain lit where is the flame sensor located?
follow small black wire down from board next to ignitor in box or ignitor on burner clean up then try again
Aug 19, 2012 | Jandy Laars Lite2 Ld 175,000 Btu Heater
I have a Jandy LITE2 LG325. Only two years old.
Does the pilot light stay light? Or light then go back out? If it is doing that then it is the thermocoupler. looks like a wire that is in the flame of the pilot light. Other than the sparker. That is what dectects that there is fire in the pilot light before it starts the gas. Safety thing. So if that isnt detecting fire, then it will never let the gasvalve open up, Try taking some steel wool or real fine sandpaper and clean up that sensor. The wire. It builds up a thin film on it from gas burning.
May 11, 2010 | Jandy Laars Lt 400,000 Btu Heater
How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Jun 28, 2009 | Jandy Laars Lite2 Ld 175,000 Btu Heater
Flo 6 showing on display panel?
DO YOU HAVE ALL THE WIRES CONNECTED? IF YES POWER MODULE MUST BE REPLACE
Jun 28, 2009 | Jandy Lite2 Lj175n 175,000 Btu Natural...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Jandy pool heater model #LT400N-L service and ES1 light blinking
The heater won't fire up if there is no or inadequate water flow. Ck water pump and filters.
Jun 01, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Jandy Lite2 Pool heater will not stay lit after firing.
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
May 17, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Logo
489 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
