Question about Epson Stylus C46 InkJet Printer
Parts inside your printer are at the end of their service life. S
My epson c90 have the same problem but i dont n=know how to fix it...help me pls
  • Epson Master
  • 511 Answers
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at indoreset.blogspot.com. Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Posted on Jul 24, 2009
Greetings My Epson RX-650 has suddenly come up with a message on its screen saying: Error. Service required. Parts inside your printer are at the end of their service life. See your manual for...
Bit late to respond but in terms of information this page helps explain the problem, cause and what you can do about it.
Resetting will allow the printer to start working again but you do need to consider what you intend to do regarding the waste ink building up in your printer as well, or you risk an overflow.
Dec 21, 2010 | Epson Stylus RX650 All-In-One Printer
Parts inside your printer are at the end of their service life. See your printer documentation. 1. Download Adjustment Program for Epson C90 2. Change your PC Date to Jul 24 2007 3. Delete the folder...
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Apr 05, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
Jul 23, 2009 | Epson Office Equipment & Supplies
The status of my printer (epson stylus c45)is idle. There's this yellow exclamation point before the message-Service Required then...inside the dialogue box it's written that Parts inside your printer are...
You will need to get it serviced at an authorized Epson Repair shop as the parts that are at the end of service life are not user servicable. With the price of printers today it would be cheaper to buy a new one with updated technology than to try and have this one refurbished. Hope this helps.
Jul 19, 2009 | Computers & Internet
Flashing both light & Display service requirment, need life softwere for epson stylus c90
sir,whenever i on the printer the light blow i hear roller moving sound but it won't print out
Mar 07, 2009 | Epson Stylus Photo R300 InkJet Printer
Parts inside your printer are near the end of their service life.
if you put this in google ssc download it and this will reset your printer hope this helps
Feb 26, 2009 | Epson Office Equipment & Supplies
Resetting
Hey, I think you need to renew your components as they are going to expire very soon. So contact your service dealer for the warranty period of your components.
Jan 02, 2009 | Epson AcuLaser C900 Printer
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Dec 07, 2008 | Epson Stylus Photo R300 InkJet Printer
EPSON PRINTER R22O
Hi-
yes actually there is. the parts its talking about is the inkpad, you can send this over to an epson certifies servicer in your are to have inkpad change and they will reset the counters for it. go this link and look for a servicer near your place
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp?BV_UseBVCookie=yes
or you can contact epson at 562-276-1300
pls rate as fixya if helpful. thanks!!
Jun 21, 2008 | Epson Stylus 2200 InkJet Photo Printer
Epson printer -parts at their end of life!
get a new printer...it will probably be cheaper and easier than trying to fix it
hope this helps
Apr 12, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
228 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
