Question about HP LaserJet 4600dn Color Printer
Problem with printing from Tray 1
I'm trying to print labels, but the printer takes plain paper from Tray 2 instead of Tray 1 which prints labels.
    Scholar:
  • 122 Answers
It can be set from more then one place. In MS Word you would go into the tools setting then choose the envelope drop down, select labels and in the options for the label you choose the format as an Avery Equivalent. That is where you can tell MS Word which tray to pull from. Also in the printer properties, under advanced options you can designate what type of paper is in each tray. Good Luck
Posted on Jul 23, 2009
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
When printing it will not print from tray 2 it wants to print from tray 1 and is asking for labels. Then causing users to have to press the green check twice to change the option to print from tray 2. How...
Ok remove tray 2, and in back its got a little clicking adjustable lever that you need to move so it lines up with letter 8.5 x 11...this worked for me
Nov 27, 2009 | HP LaserJet 4700 Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Printer picking wrong tray for print
From the start menue to printers and faxes go to your printer right click and select properties label the 4 drawers as to paper type and select continue, or auto continue to off.
-Carl, please let me know if this helps.
Jun 26, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Feb 13, 2009 | Xerox Phaser 8560DN Laser Printer
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
HP LaserJet 4600dn Color Printer Logo
168 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
