Question about HP LaserJet 3055 All-In-One Printer
3055 trying to fax getting COMM. Error?
Need help.
  • 65 Answers
It's probably your phone-line that causes the problem. The fax-module in your machine needs a 100% analog phone line. HP garantees nothing when using IP/ISDN/PABX-lines. Try lowering the baud rate, turn off JBIG compression and error correction mode, but if the problem remains, you better replace your phoneline.
Posted on Jul 29, 2009
  • kthompson364 Aug 26, 2010
    Unlike most fax machines the 3055 does not seem to have a setting for your baud rate. I recommend a different brand of fax machine that does have the ability to change your default baud speed. 9600 is a good speed if you are having connection problems.
Printer laserjet 3055 give fax problem problem is fax comm.error 322
Good day.
A fax comm.error 322 usually means:
Telephone line conditions were too poor to send a fax.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the session fails after transmitting several pages of a large document, retransmit the document as several smaller documents.
You can also try disabling the ECM feature:
Reconfigure the local fax machine to use different configuration settings, toggle the ECM state and/or select a slower reception speed.
To Disable ECM, perform the following steps:
1. Press the or > button until the front display reads "Fax Setup".
2. Press the ENTER/MENU button.
3. Press the or > button until the front display reads "All Faxes".
4. Press the ENTER/MENU button.
5. Press the or > button until the front display reads "Error Correction".
6. Press the ENTER/MENU button.
7. Press the button until the font display reads "Off" and then press the ENTER/MENU button to save the setting. (Off disables ECM and On enables ECM).
TIP: It would also be helpful to check physical conditions of your phone cord and telephone filters if you are using one.
Jun 26, 2011 | HP LaserJet 3055 All-In-One Printer
Comm Error 232
This is an error during faxing, typical of static on the line or poor line quality if you are on digital phone lines contact your service provider and request filter to install on the phone line. You can purchase a filter at radio shack, but make sure that your service provider recommends the filter.
In the mean time try changing the fax speed to medium and error correction mode off:
both of these options are under the fax setup/all faxes menu
Al
Eliteprintersolutions@gmail.com
Jul 13, 2010 | HP LaserJet 3055 All-In-One Printer
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
Mar 29, 2009 | HP LaserJet 3055 All-In-One Printer
Comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Oct 21, 2008 | HP LaserJet 3055 All-In-One Printer
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Comm error
are ur telephone lead in line socket of printer of back side.
Mar 01, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
402 people viewed this question
Seeker5211
Seeker5211
