Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Both drawers Fisher Paykel DD603i start Beeping/Draining
Both drawers on my Fisher Paykel DD603i start beeping and the drain motors start running. I have not run any dishes for days. The only way to make it stop is to unplug it. When i plug it back in it is OK for a while then starts beeping/draining again.
    Problem Solver:
  • 7 Answers
The unit as had a lieak your it thinks it as first un plug the unit then try taking out the bottom draw (pull it all the way out then at the bottom front on both sides there is to clips push both clips in and pull the draw it wiil leaft of it runners push the runs back in out of the way then the can see under the in the base of the unit if the can see water or damp dathch plz call an enginner as ther is 5 things it can be
if not water you will see a grey plactic cover in the bottom back right the main pcb is in there witch has a water sencer on it if you fell up to 4remover the pcb and wiep the two prongs that are on the end of it as wiep there it was siting then put back as it was ps the dont need to take any wires to repalces the draw pull the to runners back out sit the draw on them then clothes the draw but re open it and give the to cilps a lite pull to make sure they are locked back in to places pulg it back in and try it if this dont work plz call an enginner as there is 3 pcbs in this unti that will need cheking
Posted on Jul 23, 2009
Fisher and paykel dish draw not draining
If the problem is with both drawers, then most likely kitchen side drain is blocked. But if only one drawer, then need to clean filter and drain sump at base or if pump motor is not running then replace the pump rotor.
Mar 21, 2013 | Fisher and Paykel Dishwashers
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Hello, I have a Fisher and Paykel DD603I and both drawers have a red light on the play/pause button and won't stop beeping. Can you please help me with a solution to this problem?
It sounds like the dishwasher is in flood mode. You would need to dry up the water in the base pan and test. The link below is a video that explains how to repair your fisher paykel dishwasher.
Fisher Paykel Dishwasher Repair Video
Mar 23, 2011 | Fisher and Paykel 24 in. DD-602 Built-in...
We have the double dish drawers....the lower dishwasher begins its cycle and then suddenly starts beeping with the red lights flashing....also the water is not draining. can you tell us what's going on?
It is important to find out which light is flashing - if you have an LCD display then is there any character like Fxx or Uxx on it.
Which LEDs on the drawer door lid top are on. If water is not draining then it is linked to the rotor pump or drain sump being blocked.
Nov 12, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top draw beeping delay and water not draining
Not sure what you mean by beeping "delay" I am not sure if there is any such light on the dishwasher. The HRS DELAY is displayed on the LCD when dishwasher has been set in delayed start mode. Are you seeing this flashing in an orange background? There could be several reasons for water not draining. Does the beeping go away if you press the power on/off button? Also does the delay flashing stop. Have you checked to see nothing is blocking the drain pump which is the same rotor that drives the washer arms.. What about the kitchen down pipe - is it clear? If you think you have to take the drawers out to reach the drain hose then follow instructions on page 7 step 2 of the installation manual. It is for a later model but your one should be similar. Make sure you turn the mains power off when working inside the dishwasher.
Jul 06, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
After 2 minutes top washer blinks. Water does not drain
When I opened the top drawer the water seems to be accumulating in the drawer and no water is draining. The drain tube appears normal and not kinked in any way.
Jan 13, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
Jan 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
340 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
