JVC KW-NX7000 Car GPS Receiver Logo
Posted on Jul 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KW-NX7000 NO GPS SIGNAL OUT OF THE BLUE - JVC KW-NX7000 Car GPS Receiver
Anonymous
Level 3:
Brigadier General:
  • Master 4,090 Answers
  • Posted on Jul 26, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4090
Questions
0
Helped
1183254
Points
12747
Check these options
BAUD RATE AND PORT are set correctly. most gps now have a search function which selecvts the correct options. If not consult manual
Check battery capacity as this is a major factor too low wont pick up signal. freplace if necessary.
claer view of the sky.. not inside
Could even be more serious than that burned out chip and that;s expensive to repair
1helpful
Problem with JVC KW-NX7000 Car bluetooth and gps messeage.
The bluetooth headset may not be compatible for the GPS reciever.. Check for the configurations for bluetooth.. and then install..
Sat Nav not picking up a signal will a new antenna fix it?
try a stronger antenna clouds in the sky can affect your signal too make sure the antenna is not blocked bye anything
1helpful
2answers
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
1helpful
2answers
Jvc kw-nx7000 not working after I tried to update the firmware
I just performed the update as well and ended up with the same issue. I'm hoping to drive my vehicle around to see if it will eventually detect the satellites.
I might recommend a couple of things. Not sure what JVC Support has recommended but you can try a hard reset. Button is located on the left bottom corner of the unit.
You could also attempt a factory restore. The option is located in the settings under your navigation menu.
Overall I like the unit as it seems to be a stable system., for customization and information related to what JVC considers to be propritory info absoultely sux!!! The backgrounds are hokey and screens could really use an overhaul. I have yet to find any really great solutions for working with the files and information and have started to learn on my own. Very slow going so far as I really don't want to brick the unit. If you or anybody else has a good solid recommendation other than the obvious for working into the file structure etc... please feel free to share!
My jvc kw-nx7000 is not working what do i do?
Check wiring. If all OK, then call jvc service location
I have downloaded the firmware updates to my sd card but it will not finalize, it keeps saying retry after going through the setup and resetting process. My gps says lost signal. Please help.
Are you following the instructions posted on the same place? If not download, print, and follow the instructions. http://resources.jvc.com/Resources/00/01/32/63.PDF
Hope you are not using SDHC (higher than 2GB)
1helpful
2answers
Jvc kw-nx7000 parking break by passed still no video
Connect the parking break as recommended. Then check whether the video appears when parked. If not, send it for service. If yes, then the bipass was not done correctly.
2answers
Jvc kw-nx7000 won't turn on
have you check all your power source
3helpful
2answers
KW-NX700, constant "lost gps signal" all of a sudden!
Hi,this problem exist because the navigation is bloqued, if reset the problem is the same.
The solution for this problem is:
desconect de battery car, and wait 15 minutes
conect the bactery, work`s fine
cumps
Luis Gabriel Portugal
Lutrónica
Top JVC GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a JVC GPS Expert? Answer questions, earn points and help others
