Question about U-Line Icemaker
How to increase torque of the mechanism on SP18
my Uline is working good exept sometimes. It seems to be to weak to get the ice cubes out of the mold. I have replace the electrical motor.
Is there a way to increase torque of the mechanism?
Thanks
Jorgen
  • 286 Answers
Hi Jorgen
No there isnt a way to adjust the torque. When I get this problem it's usually a leveling issue.Make sure the screws on the wall(2) is tight and not pulling away. And make sure the unit is leveled. The motor is a 3 rpm motor and I wouldnt try to change any rpms because it could cause a flood.
Tell me if this doesnt work.
Posted on Jul 24, 2009
ULine CLR2160S00 was making ice then the icemaking started to slow then none at all had refrigerant replaced last year and everything else seems to be working fine,,, just no ice
Does the ice maker get water? Could the fill line be blocked? I found on my freezer ice had formed at the end of the tube and once I removed the ice it has worked fine since.
Jun 22, 2011 | U-Line ULine CLR2160S00 Echelon Series 15"...
Our icemaker makes cubes, but leaks water from the ice tray area, creating a 2 inch block of ice in the bottom of the ice cube collection bin each night.
Have a look at the manual on page 6 for adjustment procedure.
Also, your leak may be due to a water valve that is not able to turn off 100%. Valve replacement would be necessary. Unplug your icemaker electrical, and empty the ice. Leave the water turned on. If you keep getting water collecting in the bin, you are likely looking at a water valve replacement (not hard at all, just inconvenient).
Oct 12, 2010 | U-Line ULine BI2115B00 Black Echelon 15"...
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
I have a Uline model SP18 ice maker.Recently the ice maker continues to cycle,Filling with water and at the point when it should stop the compresor turns on then off as it continues to turn,starting the...
It does sound as if you may need a new ice maker. Other than that does the compressor come on to keep the ice cold? If so is it making any type of noises beyond the typical hum?
Jun 10, 2017 | U-Line Icemaker
Uline icemaker on boat needs service..
first do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
Oct 02, 2009 | U-Line Uline Origins Series...
My uline suddenly stopped making ice. the cubes are very thin although i adjusted the knob to the maximum thickness. Sometimes it works for a day or two then stops again
You should never have to adjust it to the highest setting. You could have a sensor problem or a sealed system problem Or you could of used the wrong cleaner and now the ice isnt sticking on the grid. You can only use the u-line cleaner.
Sep 23, 2009 | U-Line Icemaker
Ice cube maker on daewoo american fridge freezer
Hi i have installed my american fridge freezer DAEWOO FRSU20DC but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to the water one. Hope someone can help thanks
Jul 19, 2009 | Daewoo Refrigerators
Uline icemaker must be manually prompted to rotate and drop cubes
If your looking for a icemaker it should be part 402. Call U-line with the serial or model number to be sure they made it.800-779-2547
Feb 24, 2009 | U-Line Icemaker
ICE BUT NO CUBES
look inside ice bin to see if auger wheel is broke,sometimes the plastic wheel cut and break,hope this helps-mike
May 25, 2008 | Avanti Freezer Compact Ice Maker - 12 lbs....
Ice Maker
some part inside ice maker has broken. Attempt to pry off cover (or remove screws if necessary) and look for any part that has broken. I will guess the part is plastic. This same thing happened to my maker and I deduced that an item had fallen into the ice cube tray and prevented the arm from coming up, thereby allowing the tiny drive motor , coupled to a speed-reducing-torque-increasing mechanism to break a part of the maker. I actually used strong epoxy glue to fix it!
Jul 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
U-Line Icemaker Logo
108 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
