Question about Pioneer DEH-P840MP CD Player
Unit powers down when faceplate attempts to go to open position
When the faceplate starts down into the open position the unit powers down and returns to the up position. It will open for faceplate removal when the ignition is turned off.
  • 626 Answers
Re: Unit powers down when faceplate attempts to go to...
Same thing happened to me twice.
Its the crappy ribbon cable that connects the faceplate to the head unit.
Its only about $12 (USD) from Pioneer directly.
It comes with instructions, its not that difficult.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 21, 2007
0 characters
3 Points
Kenwood KRC-x858 stuck halfway between closed and open
have the exact same problem. I called the Kenwood tech line and the tech reported that the ribbon cable2_bing.gif is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Jul 23, 2009 | Kenwood KRC-X858 Cassette Player
Kenwood KDC-X717 - Facplate opens when powered on, stays open. No display.
I've had this problem before. The ribbon cable needs to be replaced. They wear out every few years. Take it in for service. Or do you want to sell it? I need the face plate for mine.
Nov 06, 2008 | Kenwood KDC-X717 CD Player
Help! My CD is stuck and receiver will not power up!
It sounds like the head unit is going bad. If the CD is not that important to you dont worry about it. Also you may want to check the fuses behind the head unit. Also make sure the 12 V+ Memory backup, ground, and Ignition Wires are hooked up correctly. Well, the ignition probably is, but you never know.
I hope this is helpful!
Aug 14, 2008 | Kenwood Sirius KDC-MP225 CD Player
Faceplate will not open
Perhaps something is not installed correctly physically. Sometimes if something is a little twisted the way the unit is installed it will keep it from opening properly. Try moving the unit slightly and see if that helps.
Mar 15, 2008 | Sony CDX-M8800 CD Player
Pioneer powers off when face plate opens.
My first guess would be that the ribbon cable between the flip face and the mother board has gone bad. This is a very, very common problem. I'd suspect that above everything else at this point.
Jan 03, 2008 | Car Audio Receivers
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Detaching faceplate on dual stereo XD 7500
Got to the following lik for your manual: Refrence page 6 for instructions. With the unit off, press open to allow the front panel to slide down. Genetly squeeze the release tab located on the bottom center underside and pull faceplate down and away from unit to remove. To install insert left side faceplate first then push right side to secure. Hope this Helps L8R
Sep 18, 2007 | Dual XD-7500 CD Player
Pioneer DEH-P6900UB
make sure that you have power not only to the red wire but also the yellow wire... one is battery power the othe ris ignition on power. If it only is getting one power it might not think the ignition key is on.. also maks sure there is not a reset button somewhere that you can press with a pen...
Aug 27, 2007 | Pioneer DEH-P6900UB CD Player
Initialization Problem
Hi, I'm not an expert but if you phone 0113 202 1040 a company called unicar - they have a specialist repairs department that may be able to help you. regards
Nov 12, 2006 | Kenwood Sirius KDC-MP925 CD Player
Pioneer DEH-P840MP CD Player Logo
218 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
