Question about Epson Stylus 830U InkJet Photo Printer
Colour ink failing
I had to replace my colour ink in my 830u, and since doing this the red light remains on, everytime i force computer to check ink levels it says the colour needs replacing. i tried putting the old one back in and after several attempts it recognised the levels as being extremely low, my black recognises no problem, although without a working colour cartridge th printer wont print anything.
please help, i am desperate to print. it annoying a i only print every couple of moths and it seems that every time i do i have to replace my ink or there a connection fault etc.
can somebody recommend a cheap printer that not necessarily photo quality. i have had a good running with this priter and it was a replacement for the ever so expensive lexmark that i had before, but now ionly want to do standard printing. thanks. if you know a solution and want to buy this off me i am open to suggestions offers or even a swap.
    Scholar:
  • 134 Answers
Remove the ink cartridges and clean the sensor below them.
Possibly ink on the blocking the sensor from reading the poper ink level.
After that put the cartridges back in and then go to printers on your PC and right-click the printer on the screen and try to locate a cleaning process or if you have software installed for the printer, run it through there.
Do it a few times if need be and then check the ink level.
Head cleaning it's normally called.
If it doesn't work, then the printer might simply need replacing.
Posted on Jul 23, 2009
Changed inks and paper and the red light is still on
Try unplugging the printer, then plugging it in again. Make sure the print ink heads are secure inside the printer.
Jun 05, 2011 | Epson Stylus 830U InkJet Photo Printer
Printer does not go
After few head cleaning, ink counter running low, so ink ligh (red) flashing. Then ink counter runing out, so the light stayed on. After replacing both of ink, red light stayed on, because the compatible ink (chip) not recognized by printer. Check epson status monitor. Use original ink or refill and reset ink level counter.
May 26, 2010 | Epson Stylus C60 InkJet Printer
Epson 830u displays this message and middle button red light flashes! Do you have any ideas? John Parts inside your printer are at the end of their service life. Contact your dealer for replacement
Epson programmed their printer to monitor the waste ink counter and your printer has reached the maximum value allowed, you have to reset your printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Jan 27, 2010 | Epson Stylus 830U InkJet Photo Printer
How do I clean the printer? The black ink is threequarters empty, the coloured ink is fine. Print is non-existant with the black ink and I can't find anything that tells me what to click on to clean it?
open the status monitor, go to maintenance and click head cleaning. its better to do head cleaning 3 consecutive times f you have print problems like that, although it would waste so much ink. Good luck.
Jan 10, 2010 | Epson Stylus 830U InkJet Photo Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
The red light has come on to replace the ink cartridg, i only use black ink then i tried to reset and the red light is still on and it will not print. the colour cartridges are about 3 years old???????...
Check status monitor? See difference of chip reach ink out and not recognized. Reset chip that ink level reach ink out. Also check chip connector at ink tank and at chip itself. Plug ink tank securely. Check status monitor again. If still not resolved, try to use anither chip.
Aug 18, 2009 | Epson Stylus C86 InkJet Printer
Printer will print with almost no ink on page in colour or b/w
You have to have both the cartridge installed and then
Run a nozzle check to make sure the nozzles are clean. Try running a printer self-test to make sure the printer is running properly without using the computer.
Macintosh 9.x or earlier: Open the File menu and choose Print. Click the Ink icon. You'll see a window showing the ink remaining in each cartridge.
Macintosh OS X: Double-click the Applications folder on your hard drive. Double-click EPSON Printer Utility, select the C42 Series printer in the Printer List window and click OK. Then click the EPSON StatusMonitor button. You'll see a window showing the ink remaining in each cartridge
May 04, 2009 | Epson Stylus C42UX InkJet Printer
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
Red ink not coming through
Hi, Epson usually recommend at least 6 cleans of the print head to clear any blockages. However, be warned this can use up a lot of the remaining ink, and may not resolve your issue. You may have dried ink in the magenta tank, and I would suggest replacing the ink if the first solution does not work
Aug 18, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson 830u printer
Many problems about printer heads but most common causes are it was not installed properly in the printer. Try to check if the printer is on when you get the cartridges. it will damaged the printer if taken forcibly.
Here are some suggestions to do:
1. Check your complete set of ink. I it is filled with the color indicated.
2. if you brought a new one it must be sealed.
3. If tampered or the package is open, it may have been used by somebody.
4. Install the printer cartridges properly using the guide/ user's manual so that cartridges are taken cared off.
5. When cleaning the print heads do not put much force because print heads are sensitive. Colors from yellow, magenta, cyan and black are very small so take care of cleaning. I possible use tissue because it absorbs well without blocking the jet pin of the print heads.
6. When new settings are applied you must restart the PC so that new settings will take effect.
Thanks
jonags
Oct 19, 2007 | Epson Stylus 830U InkJet Photo Printer
Epson Stylus 830U InkJet Photo Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
