Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
I keep getting a beep and believe it is a Fault Code
My Fisher & Paykel dishwasher is starting by itself. Keeps beeping which I believe is FAult Code but I have no display panel to tell. Aftter I push stop button, will pause for 30 seconds and then beeping and dishwasher will start up again. Cannot get it to stiop. Is there a reset button?
    Problem Solver:
  • 7 Answers
Try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Posted on Jul 23, 2009
Cannot turn my fisher and paykel dishwasher off..keeps beeping and motors are running in both draws. I have taken the bottom draw out and it is dry.. I can only turn it off if I turn the house mains off...
I am assuming you infer that the bottom of the dishwasher is dry when you took the bottom drawer out. This means the floodswitch located on the power filter board at the bottom of dishwasher might be faulty. Do you get any Fault code on the display.
Apr 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer on F&P dish drawer stuck on cycle & continuously beeping
You could isolate the top drawer by taking the controller power cable out. DIsconnect mains power to dishwasher, open top drawer and remove front cover carefull after removing 2 plastic pins on each side with plier. Controller box is on left top side, remove bottom connector and cover with insulation tape. Put things back and turn power back on.
But if you want to find the fault with top drawer then that is very trick if there is no fault code on panel except beeping First clean the top panel inside door with a clean damp cloth. If this does not change the situation, then it is very likely the controller is detecting some faulty sensor - and will need to find one by one. Are you ready for it?
Dec 17, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a Fisher and Paykel washing machine model MW509NZ. it keeps going into error with Leds 3, 5, 7 and 8 illuminated and a beeping noise. What is the problem please.
this is a fault code 43 which mean the out of balance switch is either faulty or the switch isstuck in the on positionfree up or replace switch which is located just under the main board
Aug 06, 2012 | Fisher and Paykel Washing Machines
Dishwasher has power but wont start
you will need to check the fault code that you get with the beeping.
If the dishwasher has a display then it should show Fxx or Uxx.
If there is no display then find out which lights on the panel are on at the time you get the beeps.
Dec 05, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher won't *******
Turn mains power off and on after a little time.
Do you get any fault code on the display if you have LCD or if integrated, which lights are on on the drawer door?
Jun 05, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Beeping fault code Fisher and Paykel DS603
Stop the unit and check to see if it's heating when it's beeping at you. eg is it warm water inside at the time? if not you may have a faulty element.
Mar 09, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and paykel washing machine
If you can indicate which lights are displayed when the machine is beeping,that gives one the fault code to be able to tell what the fault is!!
Jun 28, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
932 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
