Question about Zanussi ZWF1630 Front Load Washer
Screw jammed in between inner and outer drum
I am going through a total dismantle to try and get a jammed screw form between drums. I have removed the front large screws and am having trouble separating the front collar from the outer drum
    Scholar:
  • 61 Answers
I take it you have the drum removed from the machine completeley, the only thing holding them together should be a rubber gasket, Have you taken the weight from the front and removed all the screws behind the weight?
could you not move the screw to the bottom of the tub, remove the heater and then remove the screw, stripping down the whole machine is a lot of work, at least an hour and a half and a sore back into the bargin.
Posted on Jul 23, 2009
Washing machine drum seems to be jammed. Filter is clear. Drive belt seems to be intact OK and intact. Any suggestions?
sounds like something jammed between the inner and outer drum.
sometimes people get curtain hooks jammed in there. Obviously turn off the power before you start dismantling it. Sometimes you can get access via the drain plug opening with a long screwdriver or something.
Mar 02, 2015 | Tricity Bendix AW1400W Front Load Washer
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
LG WM2032 HW making noise, drum moves to much, belive the bearings are shot, but it also leaked the water out of the drum when is shut down. Can just the bearing going bad cause this are is there an...
You are probably correct. If the inner drum is loose and sloppy you probably have collapsed bearings and seals.
What can also happen is that the inner drum can make contact with the outer drum and wear through it. This could be the reason for the leak.
Unplug the machine at the wall. Remove the 2 screws under the rear of the top. 'Bump' the top to the rear to unclip it, and remove.
Remove the back panel to inspect the rear of the drum. This will expose the outer drum.
If the bearings and seals have failed, you have quite a large job ahead of you.
A holed tank is another level of expense. It may be cheaper to replace the machine...Get quotes.
Good luck....Nomess
Sep 06, 2010 | LG WM-2032H Front Load Washer
The rear drum wont come off as i would expect
Yes, Undo the 32mm nut, first. And, don't get the bearings dirty with dust from the brake drums, or , if you do, replace the inner and outer bearings with new greased up ones.prev.gif next.gif REAR DRUM BRAKES Brake Drums REMOVAL & INSTALLATION CAUTION
Brake linings contain asbestos. Asbestos is a known cancer-causing agent. When working on brakes, remember that the dust which accumulates on the brake parts and/or in the drum contains asbestos. Always wear a protective face covering, such as a painter's mask, when working on the brakes. NEVER blow the dust from the brakes or drum.
  1. Raise the vehicle and support safely.
  2. Remove the wheel and tire assembly.
  3. On vehicles without rear bearing hub, remove the dust cap, cotter pin, nut lock, wheel bearing nut and washer from the spindle. Remove the outer wheel bearing. Remove the drum with the inner wheel bearing from the spindle. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. Remove the grease seal.
  4. If equipped with a rear bearing hub, remove the drum by removing the retainer screws from the drum and pulling the drum from the hub assembly. If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes. To install:
  5. On vehicles equipped without rear bearing hub, lubricate and install the inner wheel bearing. Install a new grease seal. Install the drum to the spindle. Lubricate and install the outer wheel bearing, washer and nut. Adjust the bearing preload following the procedure outlined in the "Rear Wheel Bearing'' of this section. When the bearing preload is properly set, install the nut lock and a new cotter pin. Install the grease cap.
  6. On vehicles with rear bearing hub, install the brake drum to the hub assembly and install the retaining screws.
  7. Install the wheel and tire assembly. Adjust the rear brakes as required.
  8. Apply the brakes until a firm pedal is obtained, prior to moving the vehicle.
Jul 12, 2010 | 1991 Hyundai Excel 4 Door
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
Washing machine will not drain. Check the drain filter and cleaned that. Made sure the Drain hose was not twisted or bent. What do I do???
Does the pump run when it is supposed to? If ok, check the drain hose where it is attached to the bottom of the outer drum. If there is water in the drum and you pull the hose loose at the drum, the water should run out of the hose fitting (into a bucket). If nothing or very little comes out, look for something inside the drum blocking the outlet (a stray sock or similar). If there is no removable plate nearby, then the machine must be dismantled to the point that the inner drum can be removed. Major job!
Nov 15, 2009 | LG WM2487H Front Load Washer
Zanussi jetstream 1250 coin between inner & outer drum
not that easy.
remove top. remove water hoses.remove rear half of cabinet. to do this, undo securing screws along top flange, remove two screws at bottom sides hidden behind plastic plugs and two screws at bottom back. rear half of cabinet will then pull off.
remove heater - this is held with a 10mm nut in the centre which loosen and prise heater out.
you canb then see into the gap between tub and drum ane remove coin or whatever
Nov 05, 2008 | Dryers
Drum
u need to put something like a wooden hammer handle into the hole in the spider at the back when u have put it in spin the inner drum clock wise fast so it undos the spider or pulley wheel to some people once the spider is all the way off u need to put the nut back on just so it is level with the spindle with a rubber mallet strike it fast and hard and it will move the inner drum to come out once it comes so far out u need to undo the nut and remove the inner drum totally
Sep 01, 2007 | Hotpoint Ultima WF865 Front Load Washer
Replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
Aug 29, 2007 | Zanussi FJS1225W Front Load Washer
Open Questions:
Zanussi ZWF1630 Front Load Washer Logo
100 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
