Cars & Trucks Logo
Nicholas Gregoreadis Posted on Mar 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the GROUND for the front wipers for a 1997 Jeep Wrangler tj?
_-__-___-_
Level 3:
  • Jeep Master 20,706 Answers
  • Posted on Mar 05, 2017
_-__-___-_
Jeep Master
Level 3:
Answers
20706
Questions
Helped
6794897
Points
57965
Why not read the manual.?its free.
posted here 300 times, a real free book.
TJ (not unlimited) if is use that book
chapter 8w, covers all wires in car...
just click wiring. there.
page 8w-p53 its there, I see it now... try to just look.
standard wipers its G300
if g300 is bad , lots of things die....
page 8w-91-7
G300 (LHD) Left Kick Panel(usa cars that means)
pg 8w-91-4 clear as day.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Where is the GROUND for the front wipers for a 199 - g300-qw5rap5zcyyxgp3nvztly5qr-3-0.jpg nothing beats a real jeep book, ! get one?
2answers
97 jeep cj windows and wipers stopped working fuses are ok
97 wrangler right? CJ ended in 86 (last year)
97 TJ, you mean, or was posting to Cherokee correct all along./?????
factoid:
The Chrysler Corporation bought out AMC in 1987, shortly after the Jeep CJ was replaced with the AMC-designed Jeep Wrangler or YJ.
test the fuse, looking only finds the ones blow to H3LL
they can in fact just crack a bit. and are in fact bad.
use any DMM or any ohmmeter, "resistance Rx1 or RX2 range , low range) 0 ohms good, , infinity bad.
only that works. every time.
lets read the FSM together.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
wipers first. USA not export.
Front wiper not rear. ok>?
page 8w-53 wiper schematic.
fuse 2 and 3 must be good.
then fuse 14 front wiper ,fuse 12 is rear
if the fuses are good, (truely) we never ohm fuses we use VOLTS
on both sides of fuse, volts never lies.
then what is bad, easy bad wiper switch, motor or ground to motor.
the voltmeter again wins the toss and if no 12vdc to motor
then the switch or wire are bad.
if you have 12v to motor then motor is bad , if ground to motor is no cut.
now windows. what windows, are then not crank windows or zipper windows?
i think you posted wrong car,,
Front wiper on my 1997 Jeep wrangler will not turn off
Welcome to FixYa.com Unplug switch to wiper if this stops then replace switch.
Thank you for Using FixYa.com Kind Regards, Lee Your FixYa Expert and Master Technician
5helpful
1997 jeep wrangler fuse box diagram. wiper motor works....new wiper switch...connect and still no wiper function....fuse? location?
The fuse for the wipers on a 97 wrangler are located behind glove box just unhook strap that holds up glove box and replace.
What years will fit on 1997 wrangler
Anything that is for a TJ will fit your year. TJ was from 1997-2006. There were a unlimited model with a streached wheel base.
3helpful
What type of transmission do i have?
Your Wrangler is a YJ and the model is an "S". A Wrangler manufactured in 1987 through 1995 are all YJ's and then from 1997 through 2006 are all TJ's. The new Wrangler models are dubbed JK's.
Windshield wipers do not work
Hello
Welcome to FY
I would check the ground at the wiper motor
RD
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
