Question about Crown XLS 802 D Amplifier
XSL802 crown amplifier 80.7v dropped what to do
How do i change the fuse in my cts 600 amp
Try pressing the Reset Button, if that does not fix it take it to the repair shop. If you do not have experienc you can do a lot of damage.
Apr 27, 2014 | Amplifiers Crown Crown CTs 600 LITE CTs...
My xti 6002 crown amplifier ch2 shows thermal protect and fan is in full speed .what is causing the problem kindly give some tips to repair it
Crown utilizes small signal transistors as thermal tracking devices but i think that this is not the main issue with the amplifier, it could be in the output stage with some power transistors failure, does the other channel works fine?
Oct 11, 2013 | Crown XTi 6002 1200w Stereo Power...
Crown CTS 600 manual
Here i have added the link to the Operation manual of Crown CTS 600 .
Crown CTS600 Manual
Ajin
Jul 12, 2012 | Crown CTS600 2-Channel Amplifier
Which amplifier that match 2 of JBL CM52 speaker and 2 of Bose 151
If you want to run both the speakers at a time you will have to buy a professional amplifier like CROWN XLS202.
Because together the total impedance will drop below 3 Ohms. An average domestic amplifier is designed to run speakers between 4 to 8 Ohms.
If you are running only one pair at a time you can buy any of the following Amplifiers.
Marantz - PM 7003
NAD C356
Mar 31, 2011 | JBL CM52 Speaker
My XTi 2000 is very distorted intermintently. Sometimes the volume drops by at least half. I tap gently on he top of the amp and it comes back up to normal. I heard Crown has had some issues. What's the...
From your description, I would suspect some poor solder connections inside. If you know how to work on these, check for bad connections near the voltage regulators. That is the mode common area.
Dan
Jun 30, 2009 | Crown XTi 2000 2-Channel Amplifier
I need the schematic for the crown amplifier xti 1000 crown xti 1000 2-channel amplifier
These are available for purchase from Crown. Generally they are not available on the web. Is there a specific problem that you are having?
Dan
Jun 28, 2009 | Crown XTi 2000 2-Channel Amplifier
I have a Yamaha natural sound stereo amplifier a-760 but it wont turn on????? How do i repair it??
Try these for starters!
Is the power switch broke? Check the power cord! Are any internal fuses blown. Look inside for damage/burnt parts. Are the printed boards broken? after say being dropped? Is the transformer working? Check around the power supply area for faults.
Note - be careful your dealing with mains electric!
Jun 04, 2009 | Crown MA-5002VZ 2-Channel Amplifier
I have a crown ce2000 amplifier that need repair is there parts available?
Parts should be available both on the secondary market as well as from Crown. What parts do you need?
Dan
Mar 25, 2009 | Crown CE2000 Amplifier
Crown XLS 802 D Amplifier Logo
139 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
