I have a PIONEER PL155A turntable. Would someone be able to give me the physical dimensions of the Drive Belt. Diameter x width Thanks
    Scholar:
  • 113 Answers
Hi, dont know the dimensions but the belt is KEB-004 part number.
Hope that helps??
Posted on Jul 25, 2009
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
Turntable has stopped working, possible belt stretch
I don't think it's likely that the motor is in trouble just by having the belt wrong. It would require more physical damage to cause the motor to play up. Having said that the motor could have been in trouble before you touched the belt. But you do need a new belt, all you need to do is measure the diameter of the belt in mm. You might also need to measure the width. To find a new belt put the words "turntable drive belt XXmm" into Google. You can add Crosley to the start, but many belts are universal. Your measurements don't need to be spot on with the diameter, so if you have measured it at say 95mm, a 90mm to 100mm belt will do the job. However fitting the new belt is a different matter. You need to know the correct way, or the speed might be wrong. I can't help you with the fitting of it, so you will need to check how to do it. Some makes have YouTube videos of the fitting. I would just look for Crosley and see if any look like your model.
If fitted correctly and there's a problem with speed still, then you should look more closely at the motor.
Mar 26, 2014 | Crosley Stack-O-Matic CR40 Turntable
I want to buy a Jwin sterio turntable belt
Belts can be universal sometimes. What you need to do is measure the diameter in MM and then the width in MM. Put that into Google search plus the words "turntable belt" and look for the closest to your measurements given. They don't have to be spot on to yours, generally 5 to 10mm on the diameter (either way) will be acceptable, but you might want to be a lot tighter on the width.
Dec 27, 2013 | Audio Players & Recorders
Need a new belt
Measure the old belt, make certain you know how it fits before removing. You need the diameter and width in MM. You don't need to be spot on with these! Put the results with the words "Turntable belt XXmm by XXmm" into Google.
Aug 13, 2013 | Teac P-A688 Turntable
B210 belt
If you have the original measure the Diameter in mm and also the width in MM. You don't have to be spot with these measurements.
Then put the words "turntable belt XXmm (diameter) into Google. You should find something, you can narrow it down by adding the width, but I would just try the diameter first.
If you need to remove the belt make a note of how it fits first!
Jul 18, 2013 | Teac GF-650 Turntable
2003 Saturn Vue AWD 6 cyl. need to replace front bearing for drive shaft. require P/N or dimensions of bearing, ie inside diameter, outside diameter, width
Can you do some things yourself? Why don't you go to this site and find all that instead of asking someone else to do it for you.
www.getsaturnparts.com handles only new oem parts & accessories for all models of the saturn
Sep 22, 2011 | Saturn Vue Cars & Trucks
My Pioneer PL-112D turntable has a broken drivebelt, is it possible to buy a new one, and is there a diagram showing the belt "routing". Thanks.
I don't believe this belt is being provided by the Pioneer. So I did find another option at a reasonable price on E-bay.
http://cgi.ebay.com.sg/TURNTABLE-DRIVE-BELT-FITS-PIONEER-PL-12D-PL-112D-/290432607483
Jan 17, 2011 | Pioneer Audio Players & Recorders
I NEED A REPLACEMENT TURNTABLE BELT FOR TEAC JC 50 STEREO
Just measure the diameter of the old one and it's width. Then put these measurements (in mm please) into Google and and the words "TURNTABLE BELT " and you should find one. Belts are not maker specific.
Jun 24, 2010 | Teac Audio Players & Recorders
Where can I buy Pioneer turntable belts in Pietermaritzburg, South Africa?
My Auto Return Stereo Turntable , PL - 640, Quatz - Direct Drive is not playing, could you give me contact no around Pretoria or Midrand or even Johannesburg where i can send it for repairs
Apr 07, 2008 | Pioneer CDJ-800MK2 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
177 people viewed this question
 Grubhead
Grubhead
