Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia 42" LCD less than one year old - today will not turn on but stuck on "Stand By" mode. Cna you help
  • 3 more comments
  • thompson_816 Jul 23, 2009
    Message
    KDL40VL130 TV fine last evening. Awoke this morning turned on TV. depress ON TV tries to start up, begins to light switches to STANDBY then "clicks". STANDBY steady blinking
    Thanks
    Hi Again... looks like the STANDBY flashes 13 times pause flashes 13 time pause - repeats
    Sony Bravia KDL40VL130 TV fine last evening. Asoke this morning turned on TV tries to start up, switches to STANDBY then "clicks". STANDBY light flashes 13 times and pauses - repeats
    so what's the follow up?
    How do I remove status as you suggested? this forum is less than friendly
  • 3,037 Answers
The LED flashing 13 times is the indication of a bad panel. There is a chance it is something else, but there is no way to test without trying a new Main Board, Power Supply and panel. Most parts distributors charge 20% or more for restocking circuit boards used for troubleshooting, I don't think it is worth it.
You could try opening the set and looking for a blown fuse or loose connections, but that is a long shot and you would be better off either replacing the panel yourself or taking it in to get replaced unless it is under warranty which it should be if it is less than a year old which then you can call the manufacturer about your problem and they should fix it for free. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
  • 10,594 Answers
I need more info about your Sony Bravia TV for no power up problem,
1- What is exact model number of TV?
2- When you turn it ON, do you hear relay click in TV like it try to power up?
3- Does standby light blinks in TV?
Waiting your reply to provide you helpful info or solution for your TV.
Thanks.
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jul 23, 2009
    Power supply board is bad and back light inverter board is suspected.
    Well, my assistance has been rejected so I'm unable to provide you more info because of website system that does not allow me to add comments/ info any more after rejection.
    I already posted that power supply board is defective and back light inverter board can be suspected or cause of problem. If you could remove rating the solution then we can do some follow-up.
    Thank you very much.
    Hi again,
    Info about your TV problem has already been given, please replace power supply board in TV to solve this problem.
    Power supply board can be purchased from Shop Jimmy
    Thanks.
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
I am form mysore karnataka india,l.cd of sony bravia 42"horizontal blue band appears on the bottom of the screen
Check the warranty period is still valid and if it is within the warranty then get it Sony repaired under warranty.
Dec 26, 2012 | Sony KDL-52XBR9 52 in. LCD HDTV
Sony Bravia 3D Smart Tv
If your TV is a month old call sony and get the TV serviced or exchanged. You are covered under warranty.
Apr 11, 2012 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
THE POWER STAND BY LIGHT IS FLASHING RED 4 TIMES
Anything less than 5 blinks is major trouble. More likely vertical IC and circuit failure. Picture has been muted or turned off by TV. If Stand By light was blinking 5 times the Stand By might have came out self-diagnosis function or mode.
Contact Sony Service Tech for service adjustment to fix problem.
Oct 21, 2009 | Sony KDF-E42A10 42 in. LCD Television
SONY Bravia TV stuck on stand
Put some ice on the bag put it in the stand for a few hours,take the hair dryer max setting put some heat on the plastic,might loosen the moistster,and heat compound in there.Will able to lift.
Aug 24, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia stuck in stand by mode
What is wrong when it is in Stand by mode blinking red light 4 times, then pause, then 4 times....
Jul 03, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Jun 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
