Question about Samsung DVD-HR730 DVD Recorder/HDD Recorder
Wont play dvd discs
The disc can neither be played or recoreded check the disc it doesn`t matter what disc i use
  • 3 more comments
  • thelounge Dec 16, 2007
    Same Problem Here, CD & VCD play OK, can also copy from CD-R onto the hard drive, but any DVD gives the message "this disk can neither be played or recorded, please check disk"
  • FAZFAZ Jun 01, 2008
    Same Problem, DVD gives the message "this disk can neither be played or recorded, please check disk
  • garry ref Jul 29, 2008
    DVD stck on loading. HDD fine.
  • frank-duck Aug 19, 2008
    wont play dvd discs
  • maz123 Sep 11, 2008
    Heyy, i havee the samee problem!!
Hi all.
I have 'a' solution. It is a pain in the neck but what I do is just keep closing the drawer after the message "this disk can neither be played or recorded, please check disk" comes on screen until it does what it is meant to do.
I am only doing this to clear off the hard drive then I am going to buy another machine.
Posted on Jan 04, 2009
Looks like a general problem as I have same fault!
Posted on Apr 29, 2008
  • rockpebblar May 09, 2008
    advised by samsung that only sony or panasonic dvd + can be used, tried and did not work for me! they then said to return machine if within warrenty
Dvd player will play store bought DVD's but will reject other dvd's saying unknown disc when inserted
some older models wont recognize burnt DVD's
maybe Netflix discs have a macro on that doesn't allow your player to play them.
Sep 06, 2012 | Zenith XBV243 DVD Player/VCR
I have never been able to play a slideshow 0n my dv454 no matter where i had the discs burned what am i doing wrong? ps the discs play in other dvd players
Check to make sure that the format of the discs burned are acceptable by the dvd player, some companies do not support certain formats. refer to owner manual as to which ones are readable on your particular dvd player. if the dvd player plays other regular/non-burned discs, this is the probable issue,...more info is needed if this is not solution.
best of luck
Oct 17, 2010 | Pioneer DV-454 DVD Player
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
PS3 wont play blue ray or PS3 game discs
Please check the region code on the BD or DVD. It should match the region code set in the system. Otherwise the disc will not play
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Samsung DVD-VR 330 AK68-00995A-01 rejects all discs.
there could be dust on the laser. you can buy special cleaner or pull the machine appart and try to wipe the laser with a cotton budd and be carefull.
the motor could be blow?
May 31, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Rca dvd/vcr dual recorder, wont play dvd
My VCR/DVD Model # DRC6200N is not working. I can hear the DVD but no picture, do you have any suggestion what is wrong?
Jul 17, 2008 | RCA DRC8295N DVD Recorder/VCR
Sp k-970 dvd player will not play. played 1 dvd whenfirst bought now will not play any
1) Reset DVD player by powering unit off and unplugging from wall outlet for 30 seconds, then try again
2) Run a DVD cleaner
Are you getting a "No Disc" Message no matter what disc you use? Are you getting the message no matter what type of disc you use - commercial DVD vs burned DVD? If you are only having problems with burned DVD's, then make sure the discs are finalized.
Is the TV on the right channel?
If all else fails, call the manufacturer.
May 26, 2008 | Toshiba Televison & Video
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung DVD-HR730 DVD Recorder/HDD Recorder Logo
677 people viewed this question
Jerry Greenberg
Jerry Greenberg
