Question about Garden
The electric cable was cut during usage and sparks and smoke came out of the handle, now no longer working, I have checked the fuse, what can I do to get it working please.
  • 305 Answers
The wires will be melted inside the handle...open the handle and re-fix the wires.....then it should be ok
Posted on Jul 23, 2009
On my trroy-bilt lawn tractor pony i was in high grass it seem to stop cutting smoke came from the deck stop cutting the handle that engage the blade become reaaly easy to move nothing happened
It sounds like you got into a job that was too big for the machine, and you may have either burned up the drive belt, or toasted the transmission or clutch.
Someone knowledgeable about such things should be able to raise it up in the air and look underneath and discover which problem you have.
God bless your efforts.
Jul 08, 2016 | Garden
I have a hi Sun 500 UTV. It was idling in just cut off. The electrical panel no longer works. I only found one fuse at the solenoid box and it was fine. It does turn over. Any ideas
Check for spark at the plugs.
If you have spark, it's a fuel problem.
If you don't have spark you'll need to start tracing your electrical system.
Dec 06, 2015 | Cars & Trucks
Why dont i get a spark? was running fine. i folded handle wrong. now wont start. hadnt used charger to start before.
Don't connect both blgack cables. 1 is the ignition cut-off. Probabilly, one of both cables has a yellow or white striping. This is then the ignition cut-off. You won't have ignition if this cable is grounded.
Check also the cable in the area where the handle folds for damages!
Nov 21, 2014 | Garden
Corded electric mower loses power then comes back on during use
Same likely answer from several possibilities. Likely to be a poor electrical contact. Check *the supply had good contact for plug and an adequate fuse. *possible loose contact in the handle switch *if several years old, possible worn carbon brushes in motor. Easy to replace. *You should be using an RCD cut out switch. Check if mower works without it. Replace if dodgy
NB Only try to fix last two if you know what you are doing!
Aug 21, 2013 | Electric Lawn Mower
Hooking electric wheelchair battery to the fuse box and when the positive touches it sparks and smokes....whats wrong
tiny spark sometime normal but not getting hot! batteries are hooked up wrong. check polarity double double double check them
Oct 18, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Microwave sparks then will not work. Could it be the fuse? It is a Whirlpool.
It is tthe magnetron having the spark sometimes due to an insulation leak in the fitting .
Please check the spot where the magnetronis fitted to the cabin. Inside of the cabin there is a insulation cover and if some food particles are stuck on it due to non usage of food cover, then it is possible that the conduction of the food on this is smoking or causing an insulation break. So clean and remount the magnetron if not change the unit if the estimation is reasonable.
Credit if the advice helps
Aug 25, 2010 | Whirlpool GH4155XP Microwave Oven
Carpet brush turning on and off during vacumming
If the problem is only with the brush, and the vacuum motor is working all the time, then the most likely cause is a poor connection between the upper and lower parts of the machine. As you will know, the two parts can be separated easily and (especially if you do that often) the two little flat pins that make the electrical contact can become damaged. So check the pins, and the sockets they fit in to. If they are not visibly damaged, good contact can sometimes be restored by VERY SLIGHTLY bending the pins.
If you are able to check for electrical continuity between the pins in the brush part, then do so. If your machine has done a lot of work it may be that the so-called "carbon brushes" in the motor are worn out and are no longer making good contact so will need to be changed.
I hope this is helpful. If you need more information just post a reply and I'll see what else I can do. Please remember to rate this response. Good luck!
Feb 05, 2010 | Sebo Felix Fun Bagged Upright Vacuum
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
