A couple of things you might want to check. Did you know that when you thread ANY sewing machine, your MUST be raised? That is the only time the upper tension disks are spread to accept the thread when you thread the machine. If you don't do that, there's no tension on the upper thread, and that's the kind of thing that happens.
There are are other causes for that. Run you finger over the needle plate to see if there are any rough spots that can catch the thread, and do the same thing on the bobbin case. If there are, use an Emory board to file them smooth.
SOURCE: threading problem on Singer Sewing machine Inspiration 4206
This can be caused by incorrect bobbin tension or the bobbin is in backwards. Take out the bobbin and put it in according to the instructions for your Singer. If you still have the same problem try tightening the bobbin tension. Please ask if you have any questions.
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix. take the spool of thread off, remove the bobbin. look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
SOURCE: 5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
SOURCE: Bobbin stitch is loopy
4 is the "middle of the road" tension number, but it depends on the thickness of your fabric.
