Question about Belkin Computers & Internet
2nd laptop did work from belkin router but since being away in hotel will not work now we are home think it may be the settings
  • 339 Answers
It''s likely tha tthe hotel used the same subnet as your home network but has a different address for the router. This will fix itself once the DHCP lease expires but can be dealt with more quickly by doing the following:
1. Open a DOS command prompt window. If you use Vista, be sure to right click before opening and select "Run as Administrator".
2. Type "ipconfig /release" and then hit return. Wait for the prompt to return, it may be a minute or two.
3. Type "ipconfig /renew" and then hit reutrn. Once you get the prompt back you should be in good shape.
Posted on Jul 23, 2009
The Belkin wireless router was working for our home computer and one laptop, but the other laptop was not working. Later we figured out the laptop that was not working had other issues, but after calling...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Oct 24, 2010 | Belkin (F5D7231-4) Wireless Router
I have a Dell Inspiron Mini laptop. Do I need a sim card if I have Internet Service at home and a router? For Internet while away from home, do I need a sim card? (in a hotel with wireless service?)
no you dont you have wireless capability on your laptop. just turn on your wireless, click on it and it will show you all internet connections just click on your router name and it will connect. same when your away hotel will tell you their router name or (ssid) as its called.
hope this helps.
Aug 21, 2010 | Dell Inspiron Mini 9 Notebook
Belkin router not working with Mac Laptop
A brief Guide to setup with the mac here
In Order to configure the Belkin wireless router with, we will recommend this steps -
1. If it's a new Belkin router than Please take it out from the Box and Plug to the Power outlet.
2. If You have the Old Belkin router then its best to reset the Belkin router using the reset key at back.
3. Now Plug the Belkin router with modem using the internet cable
For more steps you need to visit https://fixingblog.com/install-configure-belkin-router-using-mac/
I hope it will be more helpfull for you
Jan 07, 2010 | Belkin F5D7234-4 Router
Hi folks, I have Sitecom wifi in my home - works a treat with my pc. It used to work with my Toshiba laptop. Then I stayed in an hotel in France, fiddled around successfully to get wifi in the hotel, and...
Click on Start > Right Click on "Network" and choose "Properties".
Click on "Connect to a Network" about in the middle of the screen under Wireless networks are available.
Find your router's SSID in the list and Right Click on it and choose "Properties".
Change the Encryption type to whatever your router is set up as. Example: Choose WEP and type in the 64 or 128 bit key that matches to your router.
If you are unsure what security options are set up on your router, please refer to your routers documentation on how to retrieve or change that information.
Dec 11, 2009 | Microsoft Windows Vista Home Basic Edition...
Want to connect 2 routers to 1 modem
as far as I know it would not work due to auto configuration of DHCP settings in the router when using cable internet. You may have to manually configure this to get it to work. If you are using dsl, I dont think it will work at all.
If it was to work, this is how I would do it:
Using Cat 5 cabling
Modem -> N Router -> G Router
Be sure to plug modem into the uplink port on N router. Then go from port 1 on N router to uplink on G Router. Set both routers to DHCP setting and see if that works. Im going to try this when I get home. It actually sounds ideal, never thought of it myself.
Hope that works for you!
Sep 22, 2009 | Belkin (F5D7231-4) Wireless Router
Wireless connection problem
When you say "IP and DNS settings are correct", can you define what "correct" is? IP and DNS settings change depending on the wireless network they're using, so one setting will not work for all networks. The most "correct" setting you can have is probably DHCP - which is called "Obtain IP address automatically" and the same for DNS. If your laptop has any statically assigned IP information, make a note of what they are, and then change it to DHCP and see if you have better luck. If you have statically assigned IP information, it will allow you to connect to the wireless network, but not provide internet access because your IP scheme and DNS settings are wrong. It sounds like the scenario you're describing.
May 17, 2009 | Dell Inspiron 8000 Notebook
My laptop will connect with the internet though a home router. At a hotel or airport it will not connect with the internet service provided by these places. What is wrong
More information needed:
Does your laptop have a wireless adapter?
How do you connect at home? (wireles or ethernet cable?)
What brand of laptop do you have?
What troubleshooting steps have you already taken?
For your information, when away from your home network, you must change your wireless settings to point to the hotel or airport provider where you are trying to connect.
Usually hotels have some contact information and some basic support (some better than others) for their wireless connections.
Dec 29, 2008 | Computers & Internet
Connecting a laptop to belkin wirless router
Check the wireless settings of your router, ssid, channel and wireless security. Set thoe information on your laptop so that it will work wirelessly with the router.
Aug 17, 2008 | Belkin Computers & Internet
Connecting PS3 via Belkin router to internet, wirelessly
I HV COMCAST AND THE BELKIN ROUTER AND I WANTED TO NO HOW CAN I CONNECT MY PS3 TO THE ROUTER.
Oct 28, 2007 | Computers & Internet
Wireless adapter
it depends what kind of wireless adapter you have in your 2nd computer. Some time there are compatability problems. just write more abt the hardware you have on 2nd computer.
Jun 04, 2007 | Belkin (F5D5231-4) Router
Computers & Internet Logo
64 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
