Question about D-Link DIR-625 (790069292637) Wireless Router
Wireless laptop finds signal, connects to network but no internet
Hello I just purchased a new D-link wireless router. My old Sony Vaio laptop with a Linksys Instant Wireless network PC Card V3.0 finds is able to find the network and can connect to it at a speed of 11.1 Mbs. When I open a browser, I get the old familiar, "Address Not Found." At the bottom right-hand corner of the screen where the wireless icon is, I right-click, hit "Status" and the window tells me that I am Connected at a speed of 11.0 Mbs. Packets sent are 0 and received are 1. Sometimes those numbers change but it seems that the laptop is always sending and receiving. I am using a 10 digit WEP security code number, however, if I turn the security settings off at the router and just have an open network, the laptop works fine. The network adapter in the laptop apparently does not support WPA networks and supposedly supports WEP networks but I can't get this thing to connect when there is a security code. I know I am using the correct 10 digit security key on the laptop but it will not allow me internet access. D-link tells me the problem is with the Linksys card, Linksys says the card is no longer supported through customer service. Can anyone please give me some direction ? Thank you very much in advance.
Dave
I lost my pc, if it connet internet, can i find that are
Posted on Sep 03, 2009
  • 390 Answers
Just a thought but may be you can try to remove the WEP/WPA and select the connection mode based on MAC id, hope it was some help
Posted on Jul 23, 2009
Wifi not working on my sony vaio vgn-nw270f
make sure you turn the wireless switch on. It should be on either side or the front of the laptop.
Did you configure the new router and set the wireless on it?
If your internet provider is a phone company such as AT&T did you configure the router to be PPOE (and set the userid and password) and bridged the modem that goes into the router?
If your internet provider is a cable company did you set the router to be DHCP?
Does the Sony even see the wireless network in the View Available Wireless Networks list?
Did you put the wireless key in correctly?
You didn't by chance happen to hit the FN function key on the lower left portion of the keyboard + the key (F1 thru F12) that toggles the wireless on and off? The correct F1 thru F12 key to hit will have the wireless signal icon )))) or it will have the icon of a tower with the wireless signal )))).
Apr 25, 2012 | Sony VAIO VGN-NW270F/B Notebook
Where is the wireless network switch on my sony vaio fxa49 noteook
Based upon this spec sheet, your all-in-one is one short. It does not come with built-in wireless networking. Thar may explain the lack of buttonology for it. There is an OPTIONAL wireless LAN card than can be purchased and installed. See spec sheet below.
b77gpsgqziw6aaaaaelftksuqmcc
Jan 08, 2012 | Sony VAIO FXA49 PC Notebook
I pruchased a Sony VAIO VGN-TXN15 Notebook from a guy on ebay who said the notebook worked well. Unfortionatly It does not connect to the internet wireless or with the eithernet cord. I took it for a...
Did you tried cable connection to your router to see if this works?
which windows its runing on?
If wireless connection drops its not all the time your laptop issue... its router transmitted channel conflict with laptop wireless card channel....
You might fix this by changing the router wireless setting by changing the transmission channel on it.and then re connect the laptop or it may auto reconnect with it and hopefully signal will not drop.
one is network card for cable connection to internet
one is wireless card for wireless connection to your router(with internet connection)
I will write more after I get your reply. As I am in the middle of my own issue now... ;)
May 08, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Cannot get my new laptop to use my wireless connection to my adsl router- wireless g old laptop using xp no problem
For connecting new laptop using windows 7
Goto Control panel-Network and Internet--Click connect to a network on left side of pane--It should show all the wireless networks including your adsl router--Click connect it would ask for security key-Enter your security key for router-You should be able to connect.
If unable to find wireless network of router then try following steps.
> Turn off laptop
>Turn off router and modem (Disconnect power cable)
>Power on router first then laptop
>Then follow first method.
Thankyou
Sep 09, 2010 | Computers & Internet
Internet connection with Sony VAIO VGN-FS115B
Try reinstalling the Wireless LAN driver
Aug 03, 2009 | Computers & Internet
How to Connect Sony Vaio to Wireless Network
hi
there are a few steps involved
1. check to see the ip address provided to you by the ISP and group your ip address range to the same range
2. check to see if you require any DNS server addresses
3. check to see when the router is connected at the internet port from the modem then is it having signal at the port numbered 1 only or is there no signal at all ports 1-4
4. if there is signal at port1 but not on other ports then instead of connectng the cable from the modem at the INTERNET port connect it to port1 and it will be distributed to all the ports 2-3 also there will be wireless connectivity too
cheers
Pls rate if this was any help
Jun 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Wireless connection problem. laptop ip address is 60.60.x.x
D-LINK WILL HELP YOU...
Set up your new D-Link networking hardware in minutes using our new Quick Setup Wizard. The wizard will guide you through an easy to follow process to install your new hardware and connect to your network. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
Jul 05, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Cannot connect new laptop to internet
Do you have a router set up? If not two things you can do:
1) Buy and setup wireless router wired with desktop and wireless with laptop.
OR
2) Remove network cable from back of Desktop and plug into laptop each time you want to use Internet. Cheaper option but more hassle to switch back and forth.
Mar 21, 2008 | Sony VAIO VGN-N130G/W Notebook
Wireless not working
may be the connection seting is changed what you have to do is ope my network place then by the left side click view all connection then you will see your wireless connection icon righe click on it then click property then chang the seting as you want it my name is Abreham Tigabu from ethiopia
Jun 25, 2007 | Sony VAIO PCG-K35 Notebook
D-Link DIR-625 (790069292637) Wireless Router Logo
550 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
