Question about Car Audio & Video
CD wont Spin
CD will go in and the laser will try to read it but comes up with no disc, have put 4.2 volts to the motor and it spins so motor seems okay just won't under normal conditions.
    Genius:
  • 1,550 Answers
Check the motor disc spindle or change it
Posted on Jul 23, 2009
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
Cd platter on PD-S701 wont spin
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD. If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Mar 12, 2012 | Audio Players & Recorders
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
Wont play
If its not a power problem, notice that the servo motor is spinning or trying to spin with a disc in the tray.
-listen carefully for a high pitch or whinning sound of the motor.
-do you have a reading on the screen? No disc or reading disc?
One of the above can be:
1- a defective laser (it wont illuminate)
2- a broken flat cable to the laser (you wont hear clicking sound when reading)
3- a bad servo motor that can not reach its speed to read the disc (has to spin at a very high speed)
Hope you can solve the problem, succes
Aug 27, 2010 | Apex Digital Televison & Video
Ps2 disc wont spin and laser wont come on
it seems there has been a malfunction within your CD Drive, this is what is causing the CD drive to not spin or read the disc. these problems can be only generally resolved by either getting the console repaired/replaced unfortunately.
The PS2 will still turn on and run because the CD Drive does not dictate whether the console works or not, but because the CD Drive is broken, you will not be able to play games or watch DVD Films unless you have the CD Drive Repaired.
Hope this Helps ?!
Oct 27, 2008 | Sony PlayStation 2 (PS2) Console
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
PS2 Disc does not spin
just because you see read doesn't mean the laser is good.
the laser has to read the toc (table of contents) for it to read the toc it must be at the beginning, it must be at the right depth from lens to cd and the spindle must spin. now if you have to spin the spindle that means it most like is not reaching the beginning of the cd or the spindle motor is bad.
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
CD Player Motor & Laser
If motor is NOT spining, laser can't read CD.
Oct 06, 2007 | RCA RS2503 Shelf System
I need a motor assembly for a philips dvd player
i used to repair dvd and cd players, the motor wont spin until the laser focuses on the disc, so you could have a faulty laser. also the mechanism sometimes comes as a complete assembly. which will cost more than anew unit
Mar 27, 2007 | Philips DVP5140 DVD Player
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
