Question about Magic Chef CGR3742 Gas Kitchen Range
Cannot adjust flame on gas burner
Flame on two (out of four) burners stay on a low flame on every setting, I removed the knob from the front console and tried to adjust the flame by turning the screw inside the console, flame stayed the same, any suggestions
  • 1 more comment
  • ctjackeen Nov 21, 2007
    the stove is a lp gas unit, this problem only started about year ago or so,it was working fine up until then , we've had the stove for about 10 yrs now
  • Anonymous Mar 19, 2014
    all other burners good, incomplete flame around center burner
  • Anonymous Mar 20, 2014
    flame only stays as long as i depress the gas dial. As soon as I release the knob the gas goes out
    New Friend:
Signature 2000 lp gas only since I got a propane fillup it was fine before that
Posted on Jan 10, 2016
  • 248 Answers
Is this lp or natural gas? The screw you turned adjusts the low flame only. Did this just start, or has it always done this? Let me know.
Posted on Nov 20, 2007
Orifices burner flame adjusted
Most burners have an adjustment under the knob. Pull off the knob and use a slender flathead screwdriver. Turn burner down to low, insert screwdriver into knob shaft and rotate internal screw until flame is at "simmer" height. Can adjust each burner separately this way.
Jan 17, 2014 | Kenmore 71042 / 71044 Gas Kitchen Range
Burner will not stay lit. Push in knob-- flame starts, but will not stay lit as soon as you take pressure off of the knob, no matter how long you hold the knob in. Also, on other burners, I cannot reduce...
I never even saw one of these babys. Wow what a stove. The simmer issue might be fixed by removing the knob and seeing if their is a minimum flame adjustment in the stem of the gas valve. The non lighting issue could be some sort of flame sensing device not recognizing the fire is lite, you could try holding in on the knob a little longer to allow the flame sensing device to pick up OR get a brush and clean around the ignitor. She sure is a beauty. The constant ticking is usually a stuck spark switch.
To find the one that you suspect is stuck you must remove a wire from each switch till you find that one
This video shows how to adjust flame:
Jan 15, 2011 | La Cornue Grand Palais 180 Dual Fuel...
The front right burner has very low flame and stays that way no matter how you adjust the knob. No smell of gas. I cannot use it the most important burner.
There are several small channels near the burner that the gas must pass through and one these is partially blocked. There are several channels or small holes that direct the gas horizontally to the point where the flame begins, and there is a small orifice (usually in a brass connector) that directs the gas upwards in the dead center of your burner assembly.
Gently pass a broom straw through these holes to clean them out. Do not use any metal pieces else you may enlarge the holes.
Jun 25, 2010 | Kitchen Ranges
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
On my range GE Profile XL44, the front burner will not turn off, the flame stays on, the knob is hard to turn and will strip if I press it too hard, I had to turn the gas going to the range.
REMOVE THE KNOB BY PULLING OUT ON IT. LOOK IN THE CENTER OF THE SHAFT THAT THE KNOB GOES ON.....IS IT HOLLOW? CAN YOU SEE A SMALL SCREW HEAD IN THE HOLE? IF SO, YOU CAN TURN THIS SCREW CLOCKWISE FOR MORE FLAME AND COUNTERCLOCKWISE FOR LESS FLAME. YOU WILL NEED A VERY SMALL DIAMETER FLATBLADE SCREWDRIVER FOR THIS ADJUSTMENT AND MAKE SURE YOU PUSH BLADE INTO SCREW SLOT FIRMLY AND TWIST FIRMLY TAKING CARE NOT TO STRIP THE HEAD OF THE SCREW. ALWAYS PERFORM ADJUSTMENT WHILE BURNER IS ON WITH FLAME LOW.
Jan 28, 2009 | Kitchen Ranges
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Burner flame adjustment
there are two considerations for burner height. 1) the gas adjustment screw on the knob and 2) the gas-air mixture to the burner. establish a flame and adjust the screw for a standing flame at the burner. adjust the gas-air ratio orifice so that the flame has no yellow tips.
Aug 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Magic Chef CGR3742 Gas Kitchen Range Logo
1,739 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
