Question about Frigidaire FGB24T3A Gas Single Oven
F1 flashing and blinking in middle of baking - Frigidaire FGB24T3A Gas Single Oven
  • 473 Answers
F1 Circuit board defective Replace control board
F1 for frigidaire means it has a defective erc (control board)
Posted on Nov 20, 2007
2 Suggested Answers
  • 58 Answers
SOURCE: when i preheat my oven
Unfortunately F1 code means you have to replace the clock.
Posted on Sep 18, 2010
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
WHAT CAUSES THE F1 LIGHT TO FLASH DURING BAKING?
most commom problem for f1 is the tempreture sensor in oven, however also ive seen alot of clocks needs to be replaced for f1. without testing sensor im not sure witch one.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F1 message flashing, annoying beep in the middle of the night
you could have a bad touch pad or ECU which is the main control board.
Sep 16, 2009 | Amana AOCS3040 Electric Single Oven
F1 when bake on oven is 350 degrees.
You also have a defective electronic control. Replace the clock.
Aug 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My Frigidaire FGF354BGWC flashes F1 and beeps
Electronic control has detected a fault condition. Turn the Temperature Control Knob to OFF,
and disconnect the power to the range. Wait 30 seconds and reconnect the power. If fault
recurs, disconnect the power and contact an authorized servicer.
Dec 17, 2008 | Frigidaire FGB24L2A Gas Single Oven
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
Frigidaire FGB24T3A Gas Single Oven Logo
164 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
