My screen only displays after 4 /5 hrs
My screen remains dark and blank after the computer has been switched on for at least , 4/ 5 hours, then lights up and works perfectly. If I dont use the computer for half an hour, the screen goes to sleep and wont switch back on for about 20 minutes. Please can someone helpme. Is there something I should know?
  • selectsafari Jul 23, 2009
    I will try to get another computer to test it. if the monitor is broken, what part of it is broken since it works perfectly when it does come on? Thanks for your interest, I am beside myself since there isn't any support where I live in South Africa, Its a Mag innovision Model 780, Made in China, and no one knows it , not even Mag Innovision.com!!! Don't know where it was bought. Thanks Again, Bev Barrett
  • Andrej.cet May 11, 2010
    might be broke or auto power off features of the monitor itself or the settings in computer's bios or in windows were set set to rather weird vales - could be a graphics card problem, also. connect that monitor to another pc - still same prob's- it is the monitor then...
    Scholar:
  • 134 Answers
Try a different screensaver.
Also look in the display properties by simply right clicking the desktop and clicking properties.
Then locate power management.
the initial seems to be a bad screensaver judging by the 20 minutes, but the 4-5 hours seems to be a sleep mode that bypasses the screensaver issue.
Posted on Jul 23, 2009
Toshiba Portege r200 was working normal (up until yesterday). Today, when I first turned it on, the fan was on and it sounded full blast, but screen remained dark (blank). I held power button until it shut...
The part that supplies the power to the screen is gone. I recall is is called the 'exciter'. They can be replaced, so take it to a computer repair shop. Same thing happened to my Toshiba.
Aug 18, 2017 | Toshiba Portege R200 Notebook
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
My hp vs19e monitor has dark screen and blinking power button.
Could be the power module or the backlights (more likely backlights if the "luminance" varies)- $156 sounds a little high but not insane, but you realize cost of replacement is lower, do you not?
Aug 13, 2009 | HP vs15 15"LCD Flat Panel Monitor
Battery not charging screen blank n when power on
check the connectivity of the charger using a multimeter. if there is anything wrong in it, you might have to open up and replace the wire in the charger. if the connectivity in the charger has no problem, then try replacing your batteries
May 28, 2009 | Koss KS4110 DVD Player
Lenovo IdeaPad Y530 - 40512SU screen dark
Their may be a problem within the Inverter man.
Oct 27, 2008 | Lenovo 3000 V100 Notebook
Blank Screen - No Display though computer power light remains switched on.
You people are not explaining in detail what is actually wrong?.  If you do this we can try to help you.
1 Does the power lights light up.
2 Does the hard-drive light light up
3. Does anything go on the computer.
4 What does and what does not (lightup)
Just because you have a blank screen does not necessarily mean the screen is "had it" and by plugging an external monitor to see if there is problem does not exist.
For all we know your motherboard may have ceased to exist or your hard drive crashed or your memory chip.  Please help me to help you?
Oct 12, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
