Question about HP Deskjet 5940 Photo InkJet Printer
My HP Deskjet 5940 refuses to turn on!
I have had the printer for at least a year and apart from the usual paper jams now and again, it has worked fine.
Then this evening I find that it refuses to turn on. I check the cables going into the printer and then make sure that the mains is connected- all these are fine but the printer still does not work.
I wonder if anyone would be able to offer a quick solution. I have emailed HP but know that they can take quite a long time to respond.
Also does anyone know if HP have on-line technical chat support and where to access this? I have done this with Dell and it was very useful but know that the sites tend to try to hide it away as it is free and saves you having to waste around £1 a minute on the phone.
All help gratefully received!
  • Anonymous May 19, 2008
    My problem is the same as Lucozade's. We've checked all the connections. What else can we do? GSM
    President:
  • 2,351 Answers
No quick fix but I do have a link to online chat.
http://welcome.hp.com/country/us/en/contact/chat_1.html?jumpid=hpr_R1002_USEN
Luck!
& please vote...
Posted on Feb 25, 2008
My HP 5940 printer squeaks when it prints. What should I do?
Nothing really. Some are just noisy. Probably some paper dust. You can clean it carefully if there is any obvious dust with a vacuum
Nov 18, 2011 | HP Deskjet 5940 Photo InkJet Printer
After printing a page my printer spits the page out very hard and then the light indicator starts to flash and on my monitor there is a message about paper jam (misfeed)
PLEASE CHECK THE SIZE OF PAPER SELECTED IN SOFTWARE SIDE. THAT MIGHT BE SMALLER THAN PAPER PLACED IN THE DRAY. A PAPER SIZE MISMATCH SHOULD BE CHECKED. SOFTWARE SIDE(COMPUTER SIDE) PAPER SELECTION SHOULD BE SAME AS PAPER IN PRINTER
Feb 09, 2011 | HP Deskjet 5940 Photo InkJet Printer
Hp Deskjet 5940 printer showing an error msg. "Paper Jam' , but after through check it has been found that no trace of paper inside and the paper feed button is blinking always.
Have you completed all these steps?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00428219&cc=us&lc=en&dlc=en&product=445440&tmp_track_link=ot_search
This is mainly about clearing paper, but explains how to clear from the front of the printer and from the back. Not sure from your post if you cleared from the back as well.
A good place to check not mentioned in that page is with a flashlight inside the printer to the extreme right and left of the inside of the printer. At the end of the page are some suggestions about printer settings and paper weights that may help as well.
Dec 15, 2010 | HP Deskjet 5940 Photo InkJet Printer
A light is flashing on my printer and is not working?
It must be Paper Jam or Cartridge Error. First of all, remove the cartridges, make sure that they are working (you can try them on another printer), verify that there's no paper jam. Clean the contact points on the cartridges and on the printer (the point where the cartridges come into contact with the printer) using cotton or soft cleaning materials, dipped in alcohol/acetone/spirit.
Also clean the inner parts of the printer, open the front door as well as the rear door (the door where you clear paper jam), blow out the dust using a blower or similar machines.
Turn on the printer without cartridges installed, again switch Off and turn on again and install the cartridges. If there's no problem with cartridges or no paper jam or no physical/mechanical damage, it'll work fine.
If you need further help and if the problem persists even with new cartridges, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP Deskjet 5940 Photo InkJet Printer
The red light with the arrow pointing down keep flashing and it won't print. It the print the first page just fine. What does it mean when the red light is flashing?
Its either a paper jam error or your printer is out of paper,open your printers back cover and check properly to see where the paper jam is located.
Jun 29, 2010 | HP Deskjet 5940 Photo InkJet Printer
Can't find ink levels for my HP Deskjet 5940
The installation disk for your printer has a setup wizard that monitors your ink levels in your printer. Go through the installation again as it will not hurt anything and you should find it on one of your pop up screens that it leads you to.
Jan 14, 2009 | HP Deskjet 5940 Photo InkJet Printer
My hp deskjet 1280 printer is not coming on
well..sometimes when a paper jam occurs, it shuts the whole system down..
you may wish to remove the s/w for that printer through control panel
go here for updates drivers
re install the s/w
run test page, calibrate and clean cycles.
Mar 27, 2008 | HP DeskJet 1280 InkJet Printer
HP 5650 deskjet printer
Did you or one of your users have a paper jam recently and force the jam out of the printer? Because we've had a few 5650's do this after a jam. About 66% of the time this fixed it...
  • Removing the ink, unplugging the printer, moving the print head to the half way point, and starting the printer. If it resets at that point and lets you put the ink in, your usually gold. If it just stops and blinks again your not.
That said, I'm actually taking one apart that wasn't fixable this way right now. I think the problem may be something related to not recognizing if the cover is up/down, but still can't see why it happens or how that it is effected by the jam.
Oct 22, 2007 | HP DeskJet 5650 InkJet Printer
HP Deskjet 5940 Photo InkJet Printer Logo
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
