Question about Stanley Staple/Nail Gun Elec
Spring has come loose
I have a spring that has come loose but it is not the spring in the staple drive nor is it the spring that is attached to the pressure point rod at the tip of the gun. It is 15 mm long and 5 mm wide. Any suggestions?? Thanks
    Sergeant:
  • 384 Answers
Springs about 1/2 long by 1/4 diameter....guess it is part of the head assembly.
Posted on Jul 23, 2009
How to reload staples.
If this is a staple gun then you need to release the tab on the back of the gun. It will release a long spring with a push rod on it. Insert the new staple bundle and replace the push rod. If this is a desk top stapler then pull the top until it opens. Set staples in and close the top again. Make sure to clear out any staples that may be loose or lodged before.
Nov 29, 2015 | Staples Tools & Hardware - Others
I have a staple gun and when I pushed the trigger the staple it metal so now it's bent in the gun and part of the way out. How do I get it out?
When this happens, you have to release spring pressure against the staple strip then invert the staple gun and BEING ABSOLUTELY SURE THAT THE STAPLE OPENING IS NOT POINTED TOWARD YOU use pliers or a similar tool to remove all of the damaged staple. Reinsert the staple strip, point the gun away from you and test operation.
Jun 05, 2014 | Tools & Hardware - Others
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
I HAVE A BOSTITCH NARROW CROWN AIR STAPLER AND THE STAPLES ARE NOT GOING FOREWARD FOR THE ROD TO DRIVE THEM IN. IS THERE SUPPOSED TO BE A SPRING BEHIND THE STAPLES TO MOVE THEM FOREWARD. PLUNGER COMES...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
http://servicenet.bostitch.com/
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
The spring has come out and we don't know where to put it
The Spring keep the Staples against the Stapler driving tool. Normally there is a metal pad to push against the staples, a rod that goes thru the Spring with a metal latch that locks inside the Stapler.
Jul 01, 2009 | Stanley Staple/Nail Gun Elec
How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Jun 08, 2009 | Arrow T25 Staple Gun
There's a jammed staple but I can't figure out how to open it to fix the problem and refill it
This is how it works on the Arrow staple gun. On the back bottom, opposite end from where the staples come out, there is a little plate. Push it in and it unhooks and pops out. attached to a rod. When you refill with staples, just push them in, then put the rod back in and the spring applies the pressure.
May 31, 2009 | Staples Swingline® 36115 Staple Guns Tools...
T50 stapler gun it worked for about 15 applications then just stopped, it's not jammed, it has staples loaded properly & firing off staples repeatedly doesn't work nothing comes out??? Why would it just...
It sounds like a manufactor defect in wire harness or premature silinoid burn out,
or you simply need to make sure you plug into and outlet that works. Could be cheap but not worth repair,return as defect if possiable and buy new one before.
Please rate. Thanks jj505
Mar 27, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Stanley Staple/Nail Gun Elec Logo
161 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
