Error message to clean the filter, but it's clean.
Error message on my Hotpoint washing machine is telling me to clean the filter. I have but it's still showing the error message. Any advice?
  • 28 Answers
I would check underneath the washer to see if there is a sump filter fitted {older hotpoints used to} if there is clean this and that should sort if not fitted check all the pipes on the drain output to see if any blockage{causing a restriction} as this could be causing the computer to think the filter is blocked. i hope this is of some help
Posted on Jul 23, 2009
Error message f-05
Possible that the pressure switch is struck up in full, It will be best to remove the switch and clean or release the jamming. Also check the drain for clogging , check the INLET flow, if not clean the inlet filter as well as the outlet filter on the drain pump.
Sep 04, 2012 | Hotpoint Washing Machines
Where is the filter?
theres no filter as such you have to do whats called a maintance wash tells you in the instrutions just a boil wash to clean filters some hotpoint machines have a filter access point under the kick plate at the front bottom of the machine
May 20, 2010 | Hotpoint First Edition FEW12 Front Load...
Error message flashing Fo-5 - nothing in manual about it. Won't drain or dry
The pump filter needs cleaning.
Remove rear cover of washer.
Remove large black hose on bottom of drum
Remove and clean plastic filter inside hose.
Fit back and test.
Mar 30, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WMF720p - getting message F05 can you help? Water trickling out when draining and error message F05 appears inbetween all cycles.
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Please rate my solution.
Thankyou.t.
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Thanks.
Jan 19, 2010 | Washing Machines
HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Filter
most hotpoint have a hidden filter
take back bottom panel off. you will see a large diameter hose coming from tub to pump. undo hose at tub end. filter is inside this hose. take it out and clean it
Jun 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
