Question about Hoover Vacuums
Hoover spin scrub leaks when I turn it off
The brushes are not moving and it leaks a lot from the bottom when I turn it off. Clean water
    Genius:
  • Hoover Master
  • 1,059 Answers
There are a lot of places that it could be leaking. The most common is a valve under the hood.you will have to put water in it and watch and inspect to trace where it is leaking.
Posted on Mar 15, 2017
reddevil6
  • 1673 Answers
SOURCE: Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Posted on Jan 14, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
SOURCE: Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 02, 2008
SOURCE: My Hoover steam vac spin scrub model 4060-900 brushes are not spinning and I have lost the manual. Any ideas. Thanks. bushteachers@yahoo.com
The problem I found with one a neighbor was tossing out is the bearings in the part that drives the brushes were stuck. Lubing them up solved the problem, but took a bit of work to get into. This also provides a good chance to clean the crud out of bits that usually don't get much attention. I found mine clogged with a fair amount of pet hair.
You'll need a Phillips & Flat Screwdriver, some light machine (3-in-1) oil or Lithium (white) grease, and a lot of patience. Having a pan or something handy to keep all the little bits organized would help.
First remove both the soap & recovery tanks, they'll just get in the way & are designed to be easily removed & replaced for filing/dumping. Be sure to fold the "wings" for the recovery tank in or they'll foul removing the cover later (as will the brush speed button).
The tricky part is getting the Brush Speed knob off. It's held on only by friction, but can be tough to pull for without breaking the plastic stick it's pushed onto.
Remove the brushes. There are 4 blocks between the outer & next in rollers. Put the flat screwdriver between the gray & clear plastic, pushing gently toward the brushes. This pushes a wedge away far enough from a hole in the gray plastic to "unhook" the brush housing from the main body. Once all 4 are clear, the brush assembly should pull out easily.
Remove the 2 big screws in front of the brushes and the one at the back of the clear plastic front of the vacuum bit. The small ones at the extreme front corners hold on the clear plastic front, and can be removed if you want to clean out the vacuum channel, but are not necessary to remove to remove the top.
Toward the back sides of the top are 2 slots that hold this part on. Once the front screws are removed & the front is loose, push the side in gently & you should be able to lift the back of the cover. Push in lift both side, the top should pop right off.
Now I have the top off, holding 2 black & 1 silver long screw. In the center-front of the new-exposed guts is a box with a round top & a cone at the front with 2 screws.
This is the Brush Motor Assembly, and it's actually vacuum-powered. Remove the 2 screws holding down the from, then look for 2 large holes on the bottom of the unit behind the black "squirter bar".
There's very long screws at the bottom of these holes that also hold down the brush motor.Once the 2 bottoms screws have been fully loosened & the top-front screws removed, the brush motor should pull up easily.
On the right is a square port, in front the the brush speed stick (where the gray button pops onto). on the left is a gray & black hose, these should pull off easily, but may have some liquid in them.
Pull out the brush motor & set it on a convenient spill-resistant work surface upside-down. You should see the square-hole drice for the brushes, a gray piece of plastic, & a cresent-shaped hole.
The port at the front & hole on bottom provide an air path for the vacuum to poll air through this assembly & spin the brushes. You should see 2 screws at the back of the motor & 2 more at the bottom of holes surrounded by the gray plastic. Remove all 4 screws.
You can now pull off the bottom cover with the gray plastic. Front to back you should see the brush drive gear, an intermidiate gear, ant one of the bearings for the fan that drives the whole thing. pulling out the bearing & gears to clean out this area & lube up the gears with some Lithium Grease helps, as well as making sure the bearing is well lubed with 3-in-1 oil and/or lithium grease.
The top is held on at this point with 4 platic clips. The top doesn't need to be removed unless you *really* have to see the fan. The clips can be broken off if one is not careful, and there's nothing in there to be lubed. Best to leave it as-is.
At the top of the driveshaft is a second sealed bearing. I couldn't figure out how to get it out without braking it, lube this one in place. The bearings are supposed to be sealed, so removing the black "washer" from the bearing is done completely at your own risk. I just put some oil on there, spun it to work it in, then repeated with the white grease.
Replace the intermediate gear, the brush drive gear, then the lower sealed bearing in that order. You can spin the gears to ensure they're spinning well. Mine was OK, but after a bit of use worked the grease in & the brushes really started spinning.
Keep in mind everything here except the screws is plastic, be creful to get a snug fit with the screws without overtightening. "Gorilla-ing" the screws will just break the plastic & make the whole adventure an exercise in frustration.
Reattach the bottom plate with all 4 screws, 2 in the holes in the gray plastic, 2 in the back.
Reattach the gray & balck hoses to the left side of the brush drive. They're 2 different sizes, so there's only 1 place the smaller hose will fit easily. Place the assembly back in the machine & replace the 2 screws in the front.
Flip the machine up so you can put the 2 really long screws back into the underside of the brush drive. There's 2 guide slots on either side, make sure the brush with the indicator wheel on top goes into the big hole on the right. You may need to spin the brushes a bit to get the center squure stick to line up with the hole in the drive gear. The brushes should pop back in easily if everything's lined up right.
Put the top cover on, making sure the Brush Speed stick & center screwhole line up, as well as the back sides snap into place.
Screw down the top, then flip the unit up so you can snap the bottom-front of the top over the gray wedges on the front, then screw into place.
Replace the Recovery Tank, fill & replace the solution tank, and test-drive.
Vanger Chevane.
Posted on May 27, 2009
had my steamvac spinscrub for 3 days now. it will not **** up why?
Posted on Mar 27, 2010
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
My cousin has a Roomba vacuum like mine and her 50 lb 13 year old dog had an accident otherwise known as **** that her Roomba went over and over repeatedly while she was at her daughters house watchin
If it as my Roomba,.....,with a pair of latex gloves on and outdoors I'd open the bottom compartment and take the two spinning brushes out. Depending on how wet or dry the dog deposit is, with wet I'd put my hose on power spray and hose the two brushes clean, then soak in a bleach solution. If dry, I'd leave them in the sun to further dry and then try getting the dry majority off with a stick or brush. When the majority is off, power spray the brushes and soak them in bleach water solution. Dry brushes ASAP and with a bunch of wet wipes clean out the area around the brushes underneath. If it somehow got into the filter compartment, you've got a lot more difficult a job to clean. You don't want to get water into the motor or fan in the filter compartment. Did you get a spare set of parts, etc. with yours? If so you might just want to toss out and replace with a clean set.
Sep 10, 2014 | iRobot Roomba 560 Robotic Vacuum
Why does my Hoover F5906 Leaks from the bottom?
Water (cleaning solution) is gravity fed to the floor cleaning brushes, but the attachment hose is fed from a small pump. If it only leaks when turned on and operating, check the pump for leaks at the pump itself or the connecting hoses.
Sep 07, 2014 | Hoover F5906-900 Upright Steam Vacuum
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
Hoover spin scrub 50 leaking from bottom
Uh, may I encourage everyone to check the trigger under the handle...we went through taking the whole thing apart and it was just that the trigger was stuck in the open position, which poured the water out continually!
Apr 09, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
I have no suction from the bottom
If there are no obvious air leaks, check to see that the belt that turns the beater brush is not broken and that the beater brush has not frozen up. Remove the beater brush and clean it, spraying a bit of WD40 at each end by the hard rubber pieces that hold it in place. Turn the beater brush by hand to be sure it moves freely around the rubber pieces. When you reassemble, make sure the belt is properly installed.
Oct 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
52 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
