Question about Canon imageRUNNER C2550 Color Copier
Error code E000747-9F00 ON CANON C2550 DOES ANYONE KNOW WHAT THIS MEANS? THANKS IN ADVANCE
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
Cogz
  • 1326 Answers
SOURCE: ERROR CODE E000-0320
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Posted on Apr 15, 2008
  • 111 Answers
SOURCE: Canon Scanner Error
Possible Causes:
1. Faulty communication between the scanner and the computer
2. Insufficient power to the scanner
Solution:
1. Disconnect and reconnect the USB cable from both the scanner and the computer.
2. Ensure that the USB cable is connected directly to the computer as opposed to connecting through a USB Hub or some other USB device.
3. Restart the computer
You might also try a different USB cable.
If the problem persists after performing the steps listed above, then the unit will most likely require service.
Posted on May 15, 2008
  • 67 Answers
SOURCE: ERROR CODE E000020-01b0
your yellow drum unit is bad replace it if the error ship to 000020-02b0 replace all your drum unit because all the units could be bad but the machine will show one at a time as you replace the drum units
Posted on Jun 19, 2008
pineworks
  • 4041 Answers
SOURCE: MX850 - error code 5100 = can you help please.
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Posted on Jan 28, 2010
Canon ir c2550 error code e000025-0001
Dear
The error code indicates the toner is not supplying for (Y). The hopper motor is locked. The probable cause the sensor is not detect within 5sec. when motor is on at hopper assy. Check. the sensor,clean-replace,check the jam of motor gears,check the harness up to DC con board, check the DC con board.
Thanks.
Jan 14, 2015 | Canon Office Equipment & Supplies
Replaced cartridge still get error message
Clear the error, then hold the switch off then on.
Oct 14, 2012 | Canon imageRUNNER C2550 Color Copier
Copy of Canon ir c2550 service manual
This Canon ir c2550i has an error e000003-002 which requires shutdown.Appreciate any idea about this problem. Ron
Jan 17, 2011 | Canon imageRUNNER C2550 Color Copier
Older Canon Copier PC-6re
Then Error code means that the fuser / fixing Lamp is blown or it could be the thirmal fuse is blown. It could also a bad thirmister, that may have caused the fuse to blow. One thing you can look at, will the fixing unit get warm or hot. Do you know any copier techs, as a friend. It is not a easy job to fix this problem. You have to fix it to clear it.... Good Luck
Mar 14, 2009 | Canon Office Equipment & Supplies
Canon ir1019/1023 System Error Code E019
Waste toner full,remove drum unit and open plugs,remove waste toner,put the plugs back.Insert the drum unit again.
Oct 22, 2008 | Office Equipment & Supplies
Service error 6000 canon pixma ip3300
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Good Luck!!!
Sep 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
E000020-0010
Have you recently changed or added a new toner resently?? If so try to reinstall it or add a new toner. A E00020 is a toner desity problem. It may be a bad toner cartridge..
May 11, 2008 | Canon imageRUNNER 105 Copier
Cannon IR C5800
According to my info this is an error detecting the home position of the image transfer belt. It may be a problem with the sensor or one of the boards, but there is also mention that if there is paper in the mbypass tray in low humidity environments that due to static electrcity electrical noise may occur and result in the incorrect detection of the ITB home position.
I would say first step is if you have paper in the bypass tray, remove it and restart the machine and see what happens. If your problem still perists i would recommend that you have a Canon Techncian come out to have a look
Mar 29, 2008 | Office Equipment & Supplies
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C2550 Color Copier Logo
75 people viewed this question
old marine
old marine
