Rank: Guide
Rating: 89%, 7 votes
when on spin check to see if you can hear a low whirring noise {the pump} if the machine is not pumping or not pumping fast enough for sufficient water to drain out of the machine then the machine will not spin due to having to much water in. i would also check to see if all filters on the waste water output are clear of any foreign bodies as this will reduce the speed of which the water is pumped out of the machine{some machines have 2 filters } good luck
