Question about Dell 924 All-in-One InkJet Printer
Printer says (new) cardridge is empty - cardridge is ok
I have a new cardridge. It is working (tested with page alignment), but printer says cardridge is empty.
When I want to print a regular page, Dell blocks it and say's the cardridge is empty...
Is it possible to switch off the ink management system?
    President:
  • 2,185 Answers
Try restarting your printer and your computer.
This usually works for me.
Posted on Jul 23, 2009
Hp designjet 500 is saying ink cardridges are empty but thay are new
Here is a link where you can download a copy of the owner's manual for your printer:
http://h10032.www1.hp.com/ctg/Manual/c00748239.pdf
In the manual are detailed explanations of error messages, what to do if it won't print, how to clean the print heads, how to align the print heads, and so much more. Shown here is a page from your the manual regarding ink supply issues. (Zoom in to make print bigger)astucia01.jpg
Apr 18, 2011 | HP DesignJet 500 InkJet Printer
Replacement ink cartridge needs to be installed. Cannot locate cartridge housing.
These instructions are for color or black cardridges. Turn on the printer by pressing the power button. Flip down the front access door by grasping it on the upper right corner (just under the scanning bed) and pulling it down toward you. the cardridges will automaticly move to the right give you access to them. Press down on the top of the ink cartridge. This will release the cartridge. Slide it forward and out of the machine. Peel off the cover from the ink cardridge. This is a pink piece of plastic /tape like lift-off tab. Lift it up and off the cartridge.
Put the new cartridge inside of your Officejet J4580 by inserting it, label facing upward, into the open slot. Press it back into the unit and down lightly. You will hear it click into place. Close the access door. Wait for the alignment process to complete that will most likely require you to print a alignment page and place it in the scanner bed then press "OK".
I think thats about it
Dec 31, 2010 | HP OfficeJet J4580 All-In-One Laser...
Installed a new HP black ink cartridge; the officejet 8500 pro will not print any black print. The color ink works okay.
First print a self test page on the printer and check if you have black print on it or not.
To do that Go to your printer :-
Press Setup button -->Go to print report-->hit ok--> use arrow keys and choose the self test page.--> hit ok.
If you have the self test page fine then try to make a black copy from the printer.
Put a black font printout on the scanner glass facing downwards. Press copy black
Check if you have the black ink working.
If yess then there is some thing on the system you are doing wrong. May be the printer properties needs to be set or some settings needs to be checked.
If no then try to clean he ink cartridge and try to align the cartridge on the printer.
To align Do this
Press setup-->use arror keys to navigate to tools -->and choose the option align cartridge or align printer.
If you do not find the option in the tools option try looking for it in the print report...
On the computer Go to printer under control panel and right click on the printer and go to print prefernces --> go to the TAB called colors and under color options -->choose print in greyscale--> and under that choose the Black only option. --> hit apply and then hit ok.
Now try printing..!
Let me know if any of these steps works....
May 12, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
All toner cardridges are at least 1/2 full but
in the printer menu, scroll to Special Pages and print a Config page, Menu Map and also the Test Pages. If these appear to print colour properly the problem may be in the driver. Check the quality tab in the preferences is not set to B/W. If the problem still appears to be with the printer after printing the internal pages then recheck after restarting the printer.
Dec 29, 2009 | Konica Minolta magicolor 5430 DL Laser...
I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
  1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
  2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
  3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
  4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
  5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
Empty colour cardridge, cant print black and white
Hi!
I'm afraid that most printers nowadays simply refuse to print unless you have ink in BOTH cartridges. No workaround. At least with an
Epson you have the possiblily of buying much less expensive generic refills...If you do this always try and find reviews of the brand of refills...caveat emptor! (buyer beware)
Sorry..
Aug 22, 2009 | Epson Stylus C46 InkJet Printer
Brother dcp-120 c printing problems
I have put new ink cartridges into the machine and I get an error message... yellow and red are empty . It will not print either.
May 16, 2009 | Brother DCP-120C All-In-One InkJet Printer
Cardridge jammed
Hello hens,
Try reinstalling the CARDRIDGE, by taking them out of teh printer & then reloading them as instructed.
Also clean the printer head.
Mar 24, 2009 | Canon SmartBase MP360 All-In-One InkJet...
I have the hp d1400 series...it wont print and its telling me i have an alignment problem..it all stemed from me changing my printer cardridge
Align the new print cartridge
  1. On the Windows taskbar, click Start .
  2. Click Programs or All Programs , click HP , and then click HP Solution Center .
  3. In HP Solution Center , click Settings , click Print Settings , and then click Printer Toolbox . The Printer Toolbox opens.
  4. Click Align the Print Cartridges .
  5. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and calibrates the printer.
  6. Recycle or discard the test page.
Mar 11, 2009 | Lexmark Office Equipment & Supplies
Dell 924 All-in-One InkJet Printer Logo
159 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
