Question about Avanti ER2001G Kitchen Range
What number do i have to put my fridge on is it max top and bottom or max bottom and number 4 at the top
  • 534 Answers
Depends on whether or not your food is icing. The higher the number the lower the temp goes. This is dependant on your preference as to the temp you like it. Again, the higher the number the temp. goes. Hope this helps
Dave
Posted on Jul 23, 2009
Frig too warm on top, too cold on bottom
inside the fridge section you have a fan damper assy.if you go here you can see it
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
part number WR49X10091,the cold air comes through the damper and the fan in it blows the cold around into the fridge section,warm air rises so this is why it's warm on top and colder on the bottom.i just installed this part for a customer,unplug the machine or shut it down,remove the 4 screws that hold the top light assy. on drop it down,unplug the wire harness,pop off the cover to the water filter,remove the top two shelves then pop off the middle cover on the back wall,this allows you to remove the two screws that are behind it,remove all screws and remove the damper fan assy.look at the instructions,the one i worked on i had to remove the gasket that's on the freezer wall side and replace it with the fat gasket in the box and then put it back together again,it took me around 35 minutes to do the job.hope this helps you out
Aug 30, 2012 | Refrigerators
The fridge works but water keeps filling the bottom of the fridge. Is there a way to prevent this?
Guessing this is a top mount, freezer on top. Sounds like a defrost drain clogged. Pull off freezer cover and check for ice build up. If there is, drain is clogged, thaw and use compressed air if possible to clear drain
Aug 19, 2012 | Kenmore Refrigerators
I have power but both the fan and the compressor are not running. All the numbers that indicate the temperature setting are blinking. Is it a relay problem or a circuit board problem.
Your fridge could be in defrost mode. This only lasts fo a few minutes. If it does not start up after 30 min max your defrost timer may be bad. When your fridge kicks into defrost mode the timer turns on the defrost circuit which includes a heating element and a defrost limit switch and turns off the cooling circuit which includes the compressor and fans. The timer use to be located under the bottom of the fridge now its inside the fridge side usually under the top plastic shield or the back. If you locate the thermostate you can turn it manually with a flatblade screwdriver. good luck
Aug 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
Apr 19, 2010 | Refrigerators
CONDENSATION ON BOTTOM SALAD CRISPER SHELF OF A WHIRLPOOL INTERGRATED FRIDGE
cold,damp air,condensates on warm shiny surfaces(bathroom mirror),try putting kitchen towel under the crisper...(why they put crispers on bottom of fridge instead of on top of the cooling coils at the top of the fridge ???)
Mar 29, 2010 | Refrigerators
Kenmore fridge. freezer top works, but bottom doesn't.
Either your fan has stopped working, or it is not defrosting. Take the back panel of the freezer off and see if the evaporator coil is iced over, if it is replace the deforst heater, and the deforst thermostat. If the compressor is running the fan if the freezer should be running. Also make sure both your fridge and freezer controls are centered. Putting the freezer on the coldest setting acutally shuts off airflow to the fridge.
Dec 05, 2009 | Kenmore 71192 / 71194
Hello, i have a magic chef fridge and im trying
It is ok to tilt frige back for hinge access be sure to unplug it and brace it so it doesn't fall on you.
Nov 04, 2009 | Magic Chef CTF2126AR Top Freezer...
Freezer not Freezing
the air flow is blocked betwen fridge and frezer or even the small fan is burnt out
Jun 22, 2009 | Magic Chef CTF2125 Top Freezer...
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
Freezer and fridge areas both 50 degrees
Assuming you have a frost-free refigerator:
Is your motor-compressor running?
If so, check if you have ice in the freezer section; if so, maybe your defrost thermostat or heating element is kaput.
If the motor-compressor is not running, check in the back of the refrgerator if the defrost time is stuck open, bu turning clockwire the small test screw, with a 1/2inch screwdriver.
Dec 10, 2007 | GE GTS22KBP Top Freezer Refrigerator
Avanti ER2001G Kitchen Range Logo
383 people viewed this question
Top Avanti Kitchen Ranges Experts
Shawn DuRee
ray gallant
Tom Chichester
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
