Question about NetGear WG111 802.11g/b Wireless Adapter
Need to know the solution
Can any on tell me the prob is i have a VSNL Broadband connection using static IP with wired router. recently i bought this netgear wireless usb adapter for my Compaq V3611AU laptop. i have installed all those drivers provided by netgear on one of my desktop which is connected by wire with my router. i dont no i got all those information about wireless connectivity still i am not able to work internet on my laptop,..... can anyone find me the solution thanks
Re: need to know the solution
After a small amount of trouble, I have configured my Win 98 laptop to use
Netgear WG111v2 wireless modem to connect to my wireless router. I used
the driver from the CD that came with the modem, following the instructions and
got to the point, after rebooting a couple of times, where I was connected to the
router, but could not reach another computer on my network (or the outside world).
I double-clicked on the wireless model icon in the system tray and noticed that,
on the NetGear SMART WIZARD panel, the WEP key was set to use the
"Create from passphrase" option, even though I supplied the already generated key (the
hex numbers) during installation of the modem. (The modem was using the key
as a passphrase to create another key.)
To fix this, on the SMART WIZARD panel, I
selected the "Enter key manually" option and, er, entered the hex key (the one
the router/access point uses for security) manually.
I hit "Apply" on the Wizard and, lo and behold, I was pinging the rest of my network.
I rebooted one more time (I had some leftover bad settings in my "Network Connection"
TCP/IP entry for the WG111 connection; I reset them before the reboot
to allow my network to automatically assign an address) and I was then able
to view my favorite site (bythestadium) from my favorite browser (firefox)
Posted on Feb 12, 2008
0 characters
3 Points
When i changed my isp from talktalk to sky broadband my dell 1450 adaptor can not connect even though there is a connection via ethernet cable apparently dell say it is a software problem and want to...
When it says 'Conntected: 100Mbps" on the bottom, all it's saying is that you have a physical connection between your computer and the device it's talking to.
Now one thing you need to double check is that (I assume you have a wireless router) the router or whatever device you have connecting to your ISP modem has the correct network information. For example some ISPs will give you a static IP address that you have to manually add to your router. If TalkTalk does that, and Sky doesn't, make sure your router is automatically obtaining an IP address. This should connect you to your ISP and to the internet. Then your DELL machine should get an IP address from your router and then you should be good to go.
Let me know if you need any further assistance.
Dec 10, 2009 | Dell 1450 (D1450U) Wireless Adapter
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on May 20, 2010 | Network & Wireless Adapters
I just installed the Dlink wbr-1310 wireless router on my computer. I have a dell dimension desktop that is hard-wired (cat5 or 6 cable) directly into the router's #1 port. Previously, the broadband...
Get rid of AOL network magic. I'm not familiar with either but I do know it's designed to help people who have no idea how to setup a home network. Log on to the routers cofiguration page and look at the router status to determine what the issue is. i.e is the router dropping the internet connection or is the router not connecting properly to your computers? If your using static IP addresses then you will need to re-configure these for the new router. Start by switching back to dynamic IP on all devices connecting to the router. It may always be a firmware issue with the router. If these steps don't work try updating the firmware (there should be an option in the config page (
Jul 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have 2 laptop computers with built in wireless and I am trying to connect to internet via a D-Link 615. I have tried multiple things but it keeps telling me that my cable is disconnected and I have no...
HI. you have to check first what kid of modem u have.. im sure if the laptop is connected directly to the modem, u have a wired connection and u can connect to the internet.. if ur modem is a cable modem, u need to mac clone the mac address of the computer that can connect to the internet. u need to connect the computer that can connect to the internet to the router and do a mac clone and the internet connection settings is dhcp..if u are using a username and password to connect to the internet, u need to use the pppoe settings on the router, and if ur isp give u a static ip address, u need to set the router on static ip. how u can check the ip address, click on start, run and type cmd and it will show a dos prompt, type ipconfig/all and it will list the ip address, subnetmask, default gateway and dns server.. u need to setup the router first in order to talk to ur modem..
Jul 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I want to share my internet connection with two computers while the IP given by the vendor is static(or 1 ip). So I doubt that whether using hub/routers(for single input and multiple output ports) I can do...
A router will be the best device that can share that static ip that you have from your vendor. Router's will have an option to set it's internet connectivity to static ip and you will just need to put in the static ip address, SM, Default gatewa, and DNS servers from you vendor. And the router will do the rest.
Dec 24, 2008 | 3Com 10BaseT RJ-45 Network Interface Card...
How to connect maxg with a my netgear broadband router
Try to turn off the DHCP server in the secound router, that way it'll be a swich technically, and set the secound router's fix ip address to something different, because I'm quite sure that both routers have the same IP address and that's nogood.
Set it to anyting from to
Nov 26, 2008 | U.S. Robotics MAXg USR5421 802.11g/b...
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
Network mask:
Network mask:
Default gateway:
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Belkin G+ mimo adapter (a timely problem)
that does seem a long time to connect... is it the wireless connection or getting an IP that is the delay... if it's IP then the network icon in the taskbar will have a moving part to the icon rather than being static... kinda yello ball running along a wire (if ya know what I mean)
try THIS util to see what your signal strength is and if there any other services sharing the same channel. Maybe you need to change the channel of the router?
Jul 16, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Get router started
Have you tried entering your username and password for your isp provider? You have to enter the config page of your router and enter this information there.
Jan 31, 2008 | Network & Wireless Adapters
There is some prob with my Netgear USB
yes , first of all just tell me which windows operating system u r using on ur computer
Nov 20, 2007 | NetGear WG111 802.11g/b Wireless Adapter
NetGear WG111 802.11g/b Wireless Adapter Logo
89 people viewed this question
Top NetGear Network & Wireless Adapters Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you a NetGear Network and Wireless Adapter Expert? Answer questions, earn points and help others
