Washing Machines Logo
A
Anonymous Posted on Mar 03, 2017
How to clean filter maytag washing Mashing, type 588 After seven years of use never has been cleaned
R.A. Ellis
Level 3:
  • Maytag Master 12,731 Answers
  • Posted on Mar 03, 2017
R.A. Ellis
Maytag Master
Level 3:
Answers
12731
Questions
Helped
2613652
Points
59176
Often, there is an access to clean the filter. Should be in the manual. Probably involves removing an outer cover. It is important to do this periodically. We found all kinds of gunk wrapped around coins, nails, etc.
Is there a filter to clean on a maytag neptune washing machine
I always leave the door cracked open so air can circulate in there and dry it up till there is no mold I've never had a problem I've had this washer 17 years
2answers
1989 full size blazer with 350 TBI. Starts when cold if I push pedal to floor and won't start at all if I dont floor it. Then motor starts to load up with lots of black smoke out of exaust and stalls after...
Do a full blown fuel system cleaning and replace fuel filter. If you can, check the SeaFoam.com site on cleaning procedures. It works great for bringing the dead (stored/parked) back to life. FWIW, mashing the pedal to floor on those older TBIs actually turns fuel off on start ups. Run a good cleaner through it (sounds like injector is gummed up)
Hi I have a Maytag Atlantis MAV975OA top loader. I cannot find a lint filter anywhere and my washing is coming out covered in lint. Can you tell me where the lint filter is so I can clean it? Thankyou
Hi gmallard, it doesn't have a lint collector. This machine is a piece of junk. We're going out today to buy a new one after years of brushing down our clothes with lint brushes. I'll put the Maytag in the shed to wash my dogs pillows etc. (about all it's good for)
My legacey washer is leaving lint on clothes
Of course you've probably already done this but if not, check the filter and clean it. Additionally, you might need to wash it to remove residue from dryer sheets and BE SURE TO DRY IT BEFORE PUTTING IT BACK IN THE DRYER. If the filter is clean and washed and you're still having lint, get a dryer brush and clean down in the area where the filter goes. Also go to the vent area outdoors and clean that with the dryer brush. That area can become clogged over time and prevent the dryer from effectively removing the lint. Furthermore, check the exhaust piping. If it is bent, gently move it a little to dislodge any lint that might have gotten stuck there over the years.
Hi we are very happy with the maytag and have had ours since 2005 however for the past 6 months or so everytime i wash polo-fleece or softish type fabric it all comes out with lint / stuff all over it. we...
Use a fabric softener such as sheets sold to include with laundry in dryer. Shuts down a lot of static-cling. Also be sure to clean your lint filter frequently to save energy and dry clothes faster.
After cleaning, our dishes have a cloudy appearance and a residue is evident. It's most evident on glasses, which have an opaque appearance. We haven't changed how were washing them or the amount/type of...
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
MAYTAG mdb4100aww-cycles but bottom sprayer doesnt wash off food. replaced impeller last year.
heat was off, filter was clogged,heat on and clean filter made the difference
Dishes are`t clean ,arms dont spin during wash cycle
what is the model # how mutch water is in the basin?
Jun 28, 2009 • Dishwashers
1helpful
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
