Question about Refrigerators
Ice maker problem
Will not make ice. water is switched on. ice tray is not filling with water.
  • 3 more comments
  • luisanes Dec 19, 2007
    I already checked solenoid valves (ok), this would produce ice cubes seldomly. What is the minimum water psi required to operate on?
  • spacetaz62 Jan 24, 2008
    how do you check the water solenoid valves?
  • ImSheila Mar 15, 2008
    ice maker no longer producing ice and the bin in the door is running mighty low. Water is on and being dispensed; just installed new filter. not sure why no ice is being made. Help!
  • les28 Oct 19, 2008
    The water valve seams to not have power, I'm not sure what turns on the water valve. were would i look ? I get water to the door but none get's to the ice maker. I put the plug for the door water valve on the one for the ice maker and push the door switch and the water would go into the ice maker, so the valve seams to work. Just not sure what turns it on to send the water to the ice maker. please help.
  • Anonymous Jan 04, 2009
    i have same prolbem water to solanoid no call for water did take off unit and had some sentment in it
  • 40 Answers
Hi welem.....Is the bin arm in the down position??If not,the icemaker thinks its full and won't make or cycle any more ice.Other than that you may have a clogged or bad water solanoid valve.Located where the water enters the unit.
Posted on Nov 21, 2007
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
Kenmore 56541 side by side icemaker nor making ice The in door water dispencer works Arm on tray is on no water getting to tray
1.Bad water valve located in the back bottom of refrigerator.
2. Frozen fill tube going into back of ice maker. (common problem)
3. Ice maker not cycling. Pour water into ice maker cavity until near filled.
Wait a few hours and see if it dumps.
4.In rare cases, the switch in the ice maker body fails. Ice maker will cycle but not tell water valve to refill.
Oct 24, 2009 | Kenmore Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Water not dispensing to fill up ice maker
Hi: Make sure your freezer is at zero degrees F. It will take 24-72hrs for an ice maker to produce when the freezer is at 0 degrees. Only then will the water fill the trays. I hope this helps, Jeff
Jul 07, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
No water in ice maker
The ice maker itself sounds like its not calling for water, you would need to replace ice maker, not field servicable. did you switch the solenoid? or the wire(s) leading to solenoid??? by switch the wire(s) when you depress for water the ice tray will fill with water. reason i say that is possible that the solenoid is energized, perhaps the valve post its sitting on is no good
Mar 11, 2008 | Frigidaire FRS26F4C Side by Side...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
469 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
