Question about Polaroid FLM-1514B LCD TV
Rf signal pal to ntsc
I have this tv in ntsc system but now i am in India with pal system is ther any option i can switch it to pal with service menue or service code
  • 615 Answers
Dear Sir,
According to your post you want to change TV system from NTSC to PAL .So solution is just acess the video settings of your TV there is generally three options like this,
1.PAL
2.NTSC
3.AUTO.
If it is in NTSC select the PAL or AUTO option,because in india videos in PAL system.If TV in NTSC system it may display Black and white color only. Solution is you have to select PAL or AUTO ( In auto mode tv automaticaly switches according to the Video, may PAL to NTSC or NTSC to PAL)option.
Fixya customer Support
chandrashekhar
Posted on Jul 23, 2009
    Sergeant:
  • 273 Answers
There should be an option in your picture settings menu
I Have SONYbravia 55HX800 . It only supports NTSC brought from USA how to change the settings to PAL because i want use the television in INDIA. Please help me with the solution
some tv are not made for all type of color system. you can read the users manual for forther details. if your tv is multisystem, u can see the menu of your color tv by pressing menu button on remote. it sould be under picture settings or under tunning settings. some set top box provide color system choice. so to get correct color you need to get setellite receiver which has option to change the color system to NTSC.
Sep 22, 2011 | Sony BRAVIA KDL-V40XBR1 Television
It is used in india or not
Hello
This set RCA HD52W59 is not compactable with Indian TV tranmission system. India had s adopted PAL-B [Phase Alternating Line], system for both transmitting and receiving. This RCA set is intented to use with ATSC system, ie, it is meant for use in US only. If you get this to India, you have ot buy one RF converter, capable of converting PAL to ATSC & NTSC. You cannot get this converter from Indian market, as it has no use with Indian TVs. You have to buy it from any other source. You can see NTSC of ATSC recorded discs, and player which has these system compactabilities, but not able to receve either cable of on-air Inidan TV transmissions. OK.
Aug 27, 2011 | RCA HD52W59 HDTV Projection Television
I have connected cable (in India Tata Sky) to my Sony Bravia kdl-40V2500 (bought from USA). But I am able to see the picture all black and white and not color. I need to know how can i fix this.
Hello
Bravia KDL series are for use in US and its reception system is differnt to that of in India. Your TV can only accept signals of NTSC and ATSC. These are the statds of transmission used in US. In India, all transmisssion and recordigs standards ar of PAL. Your TV won't accept PAL system signals properly. Theese systems mentioned above anr the colour transmitting standards. You have to choose a multisystem compatable TV from there in US. There is no hopt for you to get PAL type transmission signals to recive with your tV. It can play NTSC recoreded dvds or Blu-rays or Video casette tapws, whatever it may be, properly. There is no chance to get it converted to a multisystem, or even for a PAL system converstion with your TV. The colour informatin will not be processed properly. OK.
Feb 06, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KP-51WS510 problem- 1. Picture is not stabilizing while can heard Audio clearly and continuous vertical moving picture. 2. How to connect TATA SKY INDIA DTH TO TV and convert PAL signal to NTSC or...
In your problem #1. try to do a fine tuning of the channel or adjust the horizontal adjustments. For the problem#2. Access the system setup of your television, from there you can choose either PAL signal or NTSC signal to operate in your system.
Oct 30, 2010 | Sony KP-51WS510 51" Rear Projection...
I want to play an NTSC tape on a PAL television
This is a VCR alone machine?Not a DVD and VCR combo?VCR alone machine dosen't have auto NTSC/PAL setting to play all the world regions.
May 28, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
Sony HandyCam SR10(NTSC) working with my Philips 21PT2443 model
Hi Pawan, Now I am in the same situation as you were. I am planning to buy one sony camcorder from US. But it supports only NTSC. But My TV is philips 29PT7322, User Manual says it supports, NTSC and PAL colour systems. But I am not sure it works or not. Can you please help me with your experience. Thanks in advance, Kinod
May 05, 2008 | Televison & Video
Sony Bravia KDL 52 XBR-5
If you purchased the TV in the US, it is probably strictly for use with the NTSC system and will not work with any PAL components. You can get some multi fornat devices (DVD, VCR) that will output NTSC, PAL and Secam. That is probably your best option.
Mar 15, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Polaroid FLM-1514B LCD TV Logo
644 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
