Question about ViewSonic VX924 19" LCD Monitor
Viewsonic vx924 power/inverter board
Vx924 viewsonic 19in monitor require transistor type and number q6 and q7
  • max8269 Jul 23, 2009
    q6 and q7 are two transistors on poere/inverter board surface mount component in inverter circuit
    Novelist:
  • 159 Answers
See ebay item 390074135923
http://cgi.ebay.com/2-Inverter-transistor-viewsonic-VX910-VX924-DK-QB-QO-QA_W0QQitemZ390074135923
Fran
Posted on Jul 27, 2009
    Genius:
  • 1,039 Answers
Genaric number are 2sc4672. DiGi Key has them.
Posted on Apr 22, 2010
Viewsonic VX924 monitor SMPS failed. Replaced all bad capacitors and have found that one pair of inverter driver transistors has failed. They are marked as DKQR (They are apparently Rohm 2SC4672...
When the DC filter caps no longer filter out high frequency AC, that AC will be fed through out the circuits and cause damages such as the inverter frequency will be running at the wrong frequency and caused overheating.
The service manual does not show the sch of the power supply/inverter board because it is not designed by Viewsonic.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX924/
Mar 27, 2011 | ViewSonic VX924 19" LCD Monitor
Where is the fuse in a 3701 LCD Polaroid TV/Monitor
In the Polaroid FLH-3701, the fuse is located on the power supply board, next to the AC power connector. It is a small black cylinder. It is labelled F1. Value is 5 amp, 250 volts.
A fuse does not blow for no reason. Most commonly a fuse will fail because of a short someplace on the board. I have this same TV. The fuse blew. The reason was transistor Q6 had shorted. There are two identical paired transistors on the output side. Q6 and Q7. They are both Infineon 11N60C3 MOSFET transistors. Check those for a short. There may be a burnt smell.
More commonly, this TV will fail because of bad capacitors on the power supply board.
May 08, 2010 | Polaroid FLM-3701 Television
ViewSonic Vx924 No power
If youcan take a picture or two of the boards in your system as close and clear as you can and go to our web page and email them to me I will check and see if we can help you find the problem.
Buddy
Corporate Computer
www.ccl-la.com
Aug 14, 2009 | ViewSonic VX924 19" LCD Monitor
No picture on monitor
The Q7 has a tendency to burn up transistors and a high voltage capacitor on the one half of the inverter board which is part of the power board.
I have repaired 1/2 dozen of these with that problem.
Only way to tell for sure would be to open it up and look at it.
If you can do that and send me a picture to bammbamm@ptd.net, I may be able to confirm this.
The other possible problem could be a bad bulb, but since it is fairly new ? that is probably not the issue.
Fran
Jul 20, 2009 | ViewSonic Optiquest Q7b Flat panel TFT 17"...
ViewSonic VX924 transistor
Hey Brandon.
Besides those transistors, you may also fine the large capacitor adjacent to the transformer gone too, Possibly the transformer may be bad too ?
Also the 924s used at least two style boards.
Jun 17, 2008 | ViewSonic VX924 19" LCD Monitor
Help in identifying this transistor for my VX924
Are they black with 3 SMD pads? They should have a tiny tiny number on the top corresponding to a SMD code that will tell you what they are (example: D9A means 5.5V zener diode).
http://www.tkb-4u.com/code/smdcode/indexsmdcode.php
You should be able to just get a new inverter or repurpose an inverter out of something else to get it working again. An inverter that powers any other CCFL bulb should work fine.
Mar 16, 2008 | ViewSonic VX924 19" LCD Monitor
Viewsonic lcd problem
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
The most possible causes are bad capacitors or a bad semi-conductor.
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad and can cause the power to cycle up and down. Check the area for any cracked or overheated ceramic or mylar capacitors.
Don’t forget to check for caps on the main board. Some times these boards are overly simple and only have a couple of caps, but other times they are teaming with them.
Jan 06, 2008 | ViewSonic VX924 19" LCD Monitor
Viewsonic vx924 LCD burnt transformer - T1
I did find a source for ccfl inverter transformers.The site is www.bourns.com
Oct 21, 2007 | ViewSonic VX924 19" LCD Monitor
Viewsonic VX910 CCFLamp drivers...
One and a half year later I know the solution :-). It is 2SC4672... sure!. DKQ* is in my Jaeger SMD-Decoder book (10.000 SMD - Demiconductor - Codes)
Common problem with inverter PCB. Caused by the damaged or loose 100nF (or some same value)
Succes. For me it is working.
TVMAN
Aug 09, 2007 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
2,618 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
